Need some teak advice
OHST
I bought my 1986 Aquasport 29XF six years ago. It has some teak trim in the cockpit area that I havnt touched since I owned the boat. There was no need to because what ever the previous owner used on the teak was fantastic. Well it is finally starting to wear and I should re-do it. My question is what do you think he used on the teak that let it keep its finish for six years or what would you suggest I use to get similar results?
can't tell without at least a picture ! is it glossy, like varnish ? is it pealing ?
if it has an orange tint, it could be cetol, which last pretty long, especially up north. or it could be a lot of conventional varnish... or maybe Bristol, which is a 2 part varnish.
hard to tell... 6 years is a long time though, is the boat covered most of the time ?
Thanks Pascal,
I know I said cockpit, I should have said helm, so yes it is under cover. It is not glossy, Ive varnished teak and this texture is different. There are some minor splash over spots on the fiberglass that have color, so the product must have been some type of stain. I too am thinking Sikken citol but there is no orange tint. There is no peeling, it is just fading and the natural grey color of the teak is starting to show through.
Best thing I've ever used is Sikkens, lasts for several seasons in the open. Undercover not inside it's still good after 5 years.
Do NOT varnish it! If you do, you'll have to revarnish every year or two. Reapply cetol according to the directions and it will look great again for years.
Sikkens is the stuff, I'll second that.
The only reason it has lasted 6 years is because it is covered most of the time when not in use. If it were out in the open in the elements then it most likely wouldn't last that long. I wouldn't worry about having to re-do it soon so long as you keep it covered when not in use.
