New Anchor Required.
David M
Went swimming on the way home from this weekends cruise. When the anchor left the pulpit, it kind of looked like this:
0
When I FINALLY got the damn thing to release from the river bed and it came up through the rollers it kind of looked like this:
------0
I figure I snagged
a) Jimmy Hoffa's shoes
b) one damn big log
c) one damn bigger catfish
d) Ted Kennedy's car.
In any event, the anchor is toast. Any recommendations as to a replacement. There are no markings on this anchor. It was a danforth style. I like the looks of the stealth but cannot justify the cost.
Sea Ray 330
11500 lbs dry
figure 16K fully loaded.
Anchorage is 99.99997% in the James River w/ 4 knot tidal current.
TIA
If you like the functioning of a Danforth style where you boat, upgrade to a genuine Danforth Standard or one of the improved Danforth anchors like the Danforth Hi-Tensile. The Fortress anchors are excellent Danforth Style anchors with loads of holding strength, but may not resist bending on snags as well as the stronger steel anchors.
Maybe not yzer, but they do have free lifetime parts replacement if you do bend them. I love my fortress.
Fortress anchors hold great, but you must be careful setting them. Since they are so light, if you have chain, unless you drop them very slowly, the chain hits first, and the anchor lands on the chain and won't set.
I have a Hi-tensile Danforth on the bow, once that baby hits bottom, it digs in and holds.
yeah, as a danforth the holding power of the fortress is unmatched in sand and all types of muds.
I also like the claw aka bruce. they are cheap so you can oversize it without sticker shock... around $300 for a 110lbs claw. disclaimer, i don't have as much first hand experience with the claw as i have with the FX yet but so far so good.
In any case, OVERSIZE! with your boat, i'd go for an FX37 or a 35 to 44 Claw
one last thing, with tidal current keep in mind danforth dont' always reset well as they get clogged with mud and grass... the claw might be a better choice.
Check out Ebay item # 290249016082
Fortress FX-37 used but in great shape.
Fortress anchors work great in the Chesapeake area. Plus you get to oversize the heck out of it without increasing the weight on the boat (they're quite light).
Fortress anchors are great, if you bend them up, Fortress will ship you out all replacement parts free of charge, lifetime warranty.
I don't know, when I had my Fortress it tended to "sail" quite a bit. Once I got it to bite it was good most of the time but it was definitely a more finicky anchor. And it did drag a few times, some of which it DIDN'T reset by itself.
I switched from a Fortress to a Delta, and I'm never looking back. Almost two full seasons with the Delta and not ONCE has it failed to set on the first try, and not once has it dragged, regardless of where I've anchored or the conditions. The other day my friend had re-set his danforth about five times in the anchorage because of the high winds, it kept dragging no matter how much scope he put out, he was about to give up and leave when we arrived, I told him to just let me anchor and raft up to me. As always, worked like a charm. And it takes no science to set it, drop it and fall back, and most of the time I power set it just a bit.
And good luck trying to get it bent or otherwise damaged.
There is no one good type of anchor for all anchoring. Some are better than others for universal use. I suggest you consider the type of bottom you plan to anchor in most often and then select an anchor. I used Bruce anchors for years here in Massachusetts and Rhode Island with no problems. I did use a sizable length (25-30') of either 3/8" or 7/16" chain in all occassions.
About 5 years ago, my Bruces started to fail. No, the anchors didn't change but our bottom conditions did. I found Bruce to be unreliable in ell grass and it matters not which size. I pulled a divit from the anchorage using a 44# anchor on my 30 Hunter sailboat. Talk about overkill and it still didn't work! There are areas where a Bruce will perform well, just that ell grass isn't one of them.
I switched to a 55# Delta with an all chain rode (5/16"HT) for my Silverton. Even that has given mixed results at times but I believe it was because I lacked a swivel between the anchor and the chain which is now remedied.
Foggy
With the delta and claw anchors there is a hole on the anchor where you can attach a rope with a buoy to allow you to trip the anchor for an easy retrieve if they get snagged.
Use a magic marker and write "Mooring $50 per hour" on the buoy to ensure that no one tries to pick up your private mooring.
in mud, i've never gotten the FX to drag. after a windy night, it's buried deep and it needs to be powered out. I've held with that FX55 when others have dragged...
the only time i tried a delta (an 88 on a 58 footer), it failed to set 3 times in the same exact spot where my FX always sets the first time around.
it's all about matching the anchor to the bottom!
I have Ernesto's sailing Fortress and I love it. Much better than my old danforth that never set. In fact it is not going with my boat when I sell it. Probably too light for new boat but I will use it as a rear.
I use a delta plow for my bow anchor and fortress for my stern. Both have been flawless in the areas I boat. I recently sold a fortress I had that was too big for my boat to a friend after he lost his anchor and he was very impressed when we had 4 or 5 boats all hanging off him for an afternoon. The anchor was on a trial basis with him and after that day he said sold!
FWIW the fortress I sold was never used by me since I bought it last year. When I assembled it for my friend the hole in the shaft was not right. Called fortress and I had a replacement part at no charge within a few days with their apologies. Great customer service.
We had a CQR drag big time in mud. We threw out the danforth ht and it locked up. Both 35lb. Looking to get a fortress now since we think the ICW is mostly mud/sand.
No shortage of weeds where I anchor and I changed my fortress knock-off for a Delta. I snorkel on the Delta every time I set it and I can report that it has almost always set in its own length. I set mine in the same way Ernesto described.
I've swung in circles on it in weather (nothing too serious) and it held fine. If it brings weeds up with it I find it easy to shed them, especially compared to the Fortress.
In one spot the bottom is soft silt. The anchor sets fine but it will plow a furrow in a stiff wind. It doesn't unset, and it does finally stop, but in soft silt it doesn't shine.
Where I am most everyone who sets first time and holds is using some type of plow anchor like a Delta. But as everyone says, it's very bottom dependent. Unless I move I'll always have a Delta or equivalent.
Which means I just didn't know how to work that one! LOL I think I needed more chain on it.
