new boat owner
gorodeo
hello all. im a new boat owner and i bought a used boat. it seems to need a new stater and i was wondering if anyone can give me some advice on taking it off. it is a i/o mercurer v8. any sugestions will be greatly opreciated
Can you get to it without removing the engine? Depending on how much room you have, sometimes the engine needs to be lifted a bit, hopefully not though.
Why do you think it's the starter? Tell us the symptoms first.
well it clicks when i try to start it. i cleaned the cables and tap the starter while someone hit the key and it humed
Is the battery fully charged before you do any checking the battery has to have a full charge and in good working order. Always remember check the simplest things first.
i put a new battery on it with the charger on it also. and it just would click load. is it uncomon for the starter to go out
A most imporant point is not to replace the starter with an automotive unit. It sounds as though you may just need the commutator cleaned and perhaps new brushes.
Is the engine frozen
can you manually make the engine rotate by turning the crankshaft by either turning the prop shaft in gear or turning teh harmonic balance on the front of the engine
thats what im thinking but not sure how diffcult its going to be to remove it
Also, you might check for corrosion at the other end of the cable.
Welcome! Make sure to take a safe boating course.
I agree with what Ehoyles thinks. Is the engine frozen? Try taking the spark plugs out and then trying the starter. Or, put a big wrench on the flywheel and see if you can turn the engine.
Hope you didn't pay too much for a boat that you didn't even hear run...
On some boats the engine sits low enough in the bilge that water splashing into the starter bendix solenoid is not uncommon and they can be frequent casualties. Will it start if you jump the solenoid? The engergizing coil terminal may be fine and engergizing to get the click, but still not enough juice flowing across the main terminals. You might get lucky on just a solenoid.
But never skimp on the obvious stuff first like cables and connections like others mentioned. Very common.
bp
