New oil rig blast?
ronp
http://news.blogs.cnn.com/2010/09/02/rescue-efforts-underway-after-oil-rig-accident-in-gulf/?hpt=T2 Let's hope here we don't go again.
I just heard 1 dead, 1 mile oil sheen this is not a confirmed source.
Early report of a One nautical mile x 100' medium sheen (that's SHEEN not SPILL). On second fly by sheen could not be located. If it wasn't for the British Petroleum spill, this type of incident would not have made the national news. There may a been a small blurb on a Lafayette Station or a New Orleans station but certainly no national coverage.
Here are six photographs and an update on the story.
http://www.nola.com/news/gulf-oil-spill/index.ssf/2010/09/coast_guard_confirms_burning_p.html
Okay, dumbe question time - what is the difference between a "platform" and a "rig"?
I'm confused how the yahoo link (via drudge) talks about how they put their immersibles on and our liberal friends at CNN have a picture of people floating in lifejackets and what appear to be blue jeans.
I second ITK's question. So what were they doing on there that it can blow up and not spew oil?
Remember that video of the female Coast Guard commander telling us there was no oil spill in progress after the deepwater horizon?
Lets wait and get the real facts.
There is a kids book out called "Gaston Drills an Offshore Oil Well" it shows in all the primary colors the various equipment used in offshore mineral and oil production, I wish the boob tube taking heads would read it. Quick lesson. A platform consist of a jacket and a deck section. The jacket is generally shaped like a pyramid (wide at the bottom, small at the top)and sits below the water and constructed of steel pipe and diagonal steel cross members. The jacket sits on the sea floor and is pinned in place with steel piling driven to predetermined resistance down through the main columns (legs). The deck section sits on top of the jacket and is the part you see in the photographs. The deck section contains the living quarters, work shops, storage, Production Equipment, Compressors, Heli-deck and what ever else is needed. There is not a Derrick on a production platform.
Drilling Rig----In the older days of shallow water work, the drilling package could be set up on the Platform and then removed upon completion of the well and the production equipment installed. This was costly, so in shallow water a jack up drill rigs could be floated/towed on site, jacked up on location, drill the well and if sufficient production was found a Production Platform would be built. Drilling rigs have a derrick that all people recognize as a Oil Well There are also Submersible Drill Rigs and Semi-Submersible Drill Rigs (Deepwater Horizon) and Drill Ships, but I'm not going into all that.
What could happen to cause a fire? Any thing, this is an industrial setting with electrical equipment, diesel engines and diesel fuel, natural gas fueled compressors, hot exhaust, turbo chargers, and Boudreaux with a cigarette. Look at the photos and notice the large crew boat backing hard, you don't see that kind of boat handling in your average yacht basin.
I don't see any "gumby suits" either. Looks like standard Type-1 PFD's and blue jeans to me. And with the gulf temperature at 85 or higher, I think the chance of hypothermia is pretty thin.
I'm guessing the Deepwater Horizon qualifies as a "submersible" rig (now). It's certainly submerged!!
Platforms have producing wells on them, after the rig finishes drilling the wells.
Some platforms have rigs on top of them.
Some rigs are floaters, some have legs, some are platform rigs that sit on top of the platforms.
On production platforms, there are fusible plugs, plugs that melt at different temperatures. These plugs are located every few feet on a stainless steel tubing line, located on or near any pump, control valve, manway or major flange, gas compressors, wellheads, anything that can possibly release gas or oil and cause a fire.
When these fusible plugs release the 30 lbs. of air in the tubing to the atmosphere, the Emergency Shutdown(ESD) system is activated and all automatic shutdown valves on the well head shut in within 45 seconds. After that, the hydraulic downhole valves shut within 2 minutes after the last Surface Safety Valve on the wellheads shut in. This secures all wells in case no one could activate the ESD manually.
This is not like a well being drilled, where the wellbore pressure is only held under control by the drilling fluids.
The fire burning must have been from fluids from a ruptured line, vessel or tank.
Production platforms have a lot more built in safety systems than a drilling or workover rig.
Also, there is an ESD valve on the boat landing, where they jumped into the water, that can be activate the ESD and a plastic tubing that can be broken by the workers or a boat hook from a boat to activate the ESD system from the boat landing.
All or any of these can and will prevent catastrophic failures, if they are not bypassed at the time of the incident.
It was a producing platform. There was no rig on it, no workover rig either.
Despite earlier reports, the U.S. Coast Guard said Thursday afternoon there is no sheen on the water from the Mariner Energy production platform accident .
All 13 workers from the Vermillion 380 production platform located about 80 miles off the Louisiana coast were pulled from the water by supply boat after the blast and fire, which occurred around 9:15 a.m.
The boat transferred the crew members to a nearby platform where they were later airlifted to Terrebonne hospital in Houma. One of the crew members was injured, though his status was unknown.
Firefighting vessels dispatched by Mariner had the blaze out this afternoon.
The fire occurred on a production platform that. Automated shutoff equipment on the platform turned off the flow of oil and gas from the platform’s seven producing wells before the fire occurred and the crew evacuated, the company said.
Production platforms do not have blowout preventers like drilling rigs since the nature of producing doesn’t include serious risks of sudden surges in oil or natural gas. Production platforms have shut-in and safety valves, which according to Mariner Energy, were activated.
“The fire occurred away from the well…it wasn’t involved in the area where they had oil producing wells,” said Patrick Cassidy, a spokesman for Mariner on CNBC.
The platform, located in about 340 feet of water, appears to be fairly small, producing about 9.2 million cubic feet of natural gas production per day and 1,400 barrels of oil and condensate as of August, according to the company. It is 100 percent owned and operated by Mariner.
Any time you want up to date, accruate news about the oil or gas industry, go to the Houston Chronicle website.
Click on Business section, then the Energy section. Houston is the oil center for the US, no matter what anyone
says.
Hot off the NAVTEX FA30 Message BNM 0163-10 USCG to investigate ballast tanks of all vessels that transited the Gulf during the Deep Water BP accident.
Are they kidding? I'm sure Mizz Lizza Jackson from the EPA is behind this. Maybe as a plus it will help kill the Zebra Mussels?
This is a simple fire way over blown. A step above a house fire. If it has been a gas station on land apartment in the Bronx it would barely make the news. When an airliner crashes, they report every small plane crash that week. 3500 platforms in the Gulf alone. It happens. Not a big deal.
