New Prop and listing?
BillM2
I put on a new 14.25 X 21 Merc prop on my Alpha One (up from a 14.5 X 19 Mich) and noticed that while underway, the boat was listing to port side. While docked or standing still, the boat stays even. I had to move my passengers to my side, starboard, to even the boat.
What could cause this?
Thanks!
It's not the prop. How much list...just a little or like you took a torpedo to port?
It was weird Mike. I tested the new prop underway with just me on the boat and no problem. Then my wife 115lbs, two girls 70 total, my 9 month old, 20 lbs on port side = 205 libs; me 220lbs starboard last night. Dipping considerably to port so I had my wife and me on starboard, and it evened out. How much -- about 25-30 degrees I guess. I did take the boat out of the water last week and partially cleaned the bottom -- perhaps leaving a thin film of slime in places I couldn't reach. There was no water in the bilge -- success with replacing mercathode gasket under the drive. Dry as a bone now.
I can't believe it is listing 25-30 degrees. That is the same as a fairly steep roof. Even 10-15 degrees would still be a serious listing
When you changed props did you alter the setting on the trim tab down there? That little guy is there on most Merc outdrives to offset the prop torque. You'd notice if it's set wrong as the boat won't want to track straight but will veer to one side when left to it's own.
Thrust tab was replaced pretty much as I had installed the last one. Maybe I should check. What is the correct way of mounting it. I have been pushing or bending down the tabs down into the grooves of the flo-trorq insert. Which is what I interpreted from the instructions.
Is this correct or do they stradle the ridges of the insert.
Also interested to know how that would impact listing and operation if not installed correctly.
Bah, thrust tab is the wrong term. ;) Trim tab anode, had to go look it up. ;) Is the anode gone?
Here, pictures are easier:
The circled item
If the trim tab is not adjusted properly, the boat will pull to one side or the other and be hard to steer to one side.
It was posted at some point last year that the sacrificial anode fin has little if any effect on how the boat handles whether at idle speed or cruising. You can place a rounded anode in that position or not use one. So I'm having some doubts about that being an influence on steering. Besides how would it impace listing to one side or another? So I guess my question remains: would it be possible for a prop to pull you to one side or another?
Anyone know different than that?
I agree that the trim tab (anode fin) has no effect on idle or slower speeds, but I strongly believe it does do its job of countering prop pull at high speeds.
The trim tab definitely has an effect on an Alpha one, normal prop, single engine setup. I've experienced it myself when the bloody thing wasn't set right. If it's causing the boat to not track true, then you'll have to turn the wheel to correct for it. That means when going straight ahead, the lower unit will NOT be parallel to the keel of the boat.
I would sure think this would cause a list to one side.
Very simply, does your boat, when on plane and at speed, want to turn easier one direction over the other?
That little trim tab has a major effect on a single engine setup when at speed. If set incorrectly, it will cause you to have to hold the wheel over to compensate and then the boat will want to lay up on its side.
The change in pitch you made will cause the boat to lean unless compensated for with the trim tab either on the engine or the boat.
Play with it.
