Night time light etiquette
Thompson gunr
I recently purchased a boat that has the thru hull lights in the front. (Like headlights.) My question is, whether it is proper to run these all the time at night in order to be able to see debris on the water or if they should remain off unless I am docking. I have seen other boats run spotlights under way so what is the difference with these? This is the first boat I have owned that had these lights. I can't remember seeing another boat using these lights under way. Are there rules that say NOT to use these under way or is it at the captains discretion? Of course, as with a spotlight, the light should be kept out of other's eyes for courtesy and safety sake. But are there rules that say I should NOT use them? Thanks.
I'm not sure if it's violating any nav rules, but it certainly isn't nice to do, as it can blind other boaters.
I did use them once at night and shut them off when approaching other boats but was mainly concerned with the nav rules side of this. I hate it when people shine their spotlights in my eyes at night so I am respectful of others in this issue too.
docking lights are not as bad as spot lights... there is nothing worst as someone running with a spotlight and no such thing as keeping it out of someone eyes... it will affect the other guy's night vision.
docking lights are aimed low and not as strong but will still affect an oncoming boater, use common sense and courtesy. I would not use them undeway if there is someone ahead within 1/2 mile to a mile.
i also wonder how effective they are anyway... they will light up a white or refletive buoy but not a dark half submerged log.
there are no explicit rule against them except that no light shall interfere with navigations lights. so if they are bright enough to make your red/green impossible to see, you shoudl't use them.. the other rule is the all inclusive reckless boating which would apply if you blind another guy.
Running with anything more than prescribed navlights is a violation. You are permitted to use them briefly to pick out navaids or in docking. Docking lights (yours) and spotlights are not navlights.
PLEASE>>>> use them ONLY for docking
I think you will find they don't really do much for forward visibility and lighting. They're not quite the same as a cars headlights. They can be sometimes helpful in docking when there are no other lights around. Make sure you don't interfere with the night-time visibility of other boats.
I never understood them anyway since most power boats dock stern in to the slip. You mainly see them on small boats.
"I'm not sure if it's violating any nav rules, but it certainly isn't nice to do, as it can blind other boaters."
Just one reason why you should kick in the bucks for a safety course.
Running with anything other than proper nav lights at night is the sure mark of a rookie. It screams out, "I don't know what I'm doing!"
guys... please define anything but the nav lights ! if running a boat from the flybridge or an enclosed pilothouse nothing says you can't have main cabin or cockpit or aft deck lights on as long as they dont' interfere with the prescribed lights.
I'll check my Chapman's today Pascal when I get out of the office(if I ever get out). I'm pretty sure it reads "shall show no other lights".
this is the exact rule (20):
(b) The Rules concerning lights shall be complied with from sunset to sunrise, and during such times no other lights shall be exhibited, except such lights as cannot be mistaken for the lights specified in these Rules or do not impair their visibility or distinctive character, or interfere with the keeping of a proper look-out.
pretty clear to me...
These lights are NOT effective at anything except idle speed or if I were stupid enough to be running on plane at night. (I'm not!) Anything other than that and they are pointed into the sky since they are a fixed light. They do come in handy for running into small coves to check for small logs and looking for nav bouys. Other than that I do find them for the most part useless. As I asked before, what makes them any different than a spotlight (which I have seen people leave on continually pointed just ahead of their boat)? Those lights are a LOT brighter than mine and are blinding! I'm not saying that either is right... just asking. So the proper method would be to turn them on when needed and then turn them off. Kind of ruins your night vision though every time they are turned on I would think. Best to run completely without a spot or forward lights?
What you have is the same as the twin lights found on many pontoon boats.
They are DOCKING lights. ;) That's what they're there for, to light up your trailer or slip as you pull onto/into it.
Now if you're in a cove, no one else is around and you want to check for trees, sure, go ahead and turn them on briefly. I would strongly recommend a hand held spot instead though, so you could easily move where the light is focused.
People running across the water with docking lights on are doing so illegally. They're also being quite rude to everyone else, messing up their night vision. The same goes for someone leaving a spotlight on.
When I'm out running at night, once I'm sure the boat is operating normally, I'll often dim my dash gauge lights down to the point where I can hardly see them. The screen on the GPS gets dimmed down the same. Your nightvision is too important to screw with.
That's the way I remember it Pascal, but it is open to some "interpretation" by boat owners and officials. I interpret spots and docking lights as impairing visability and distinctive character of nav lights. If you're running down the river with a spot on or your docking lights on, I can't see your nav lights well. I don't like to be confused at night.
Gary summed it up very well.
That is kind of the way I feel too. I am thinking of a remote spot for mine since I don't like these docking lights. I have a hand held now but would prefer something permanently mounted. I am going to be installing a potentiometer on my guage lights because I have already found them to be too bright and mess with my night vision. The time I did use them was in a cove and the boat I was approaching was anchored but shut them off anyway to be courtious. I just wanted to check and see if it was correct to use them at all under way. In the cove there was only a single anchored boat but at those speeds (idle) they did help some. I don't think they would work in the main channel anyway. I am glad I get feedback that my instincts are right. Just goes to show if you apply logic to boating you will likely do the safe and right thing. I VERY often see barges running up and down the river with their spotlights on contiuously. Now with a vessle that large I could understand the need to be vigilant in looking for other boats, debris, nav markers etc.. but they are just as bad about ruining my night vision as the idiots who run a small cruiser with his spot turned on. Is there a point where size wise the rules change or are both being equally discourtious? (and doing what was called above "the sure sign of a rookie") You would think a barge captain would not show "sure signs of being a rookie" but who knows? In a way, I am glad when I see that light sweep across my boat because that usually give me the feeling that he has seen me. (Although I ALWAYS act as if that is NOT the case.) I divert my eyes as I see the beam heading my way and motor on. Thanks guys.
gregory, absolutely. spotlights and docking light will interfere... other lights may not.
the second thing worst to running a narrow channel with a spotlight blinding oncoming traffic are guys coming in an anchorage aiming their spotlight on every boat anchored. that's frequent around here... a few months ago we came in a crowded anchorage at night without using our spotlight. could see just fine and had no problem finding a spot to anchor. the next 2 or 3 boats that came in aimed their damn spotlight on just about every anchored boat !
I suspect that barge captain was more interested in making sure he was seen. And if crew is moving about the deck as the barge is underway, they need to have good lighting. But I've never seen any commercial traffic moving in the Delta at night with anything but their required running lights [nav lights].
from what i understand, tow captains on rivers run with their spotlights aimed at the shoreline, not dead ahead.
larger commercial (and pleasure) passenger vessels almost always have other lights on while underway, it's absolutely legal as long as they dont' interfere with the the prescribed lights or the look out ability to do his job.
you can't expect passengers to be in complete darkness while underway...
