Night Vision Could this work???
jdshep
Goto to post below to see L3 Thermal Eye 4000M Marine Thermal Imaging Camera
Has anyone tried using a night vision security camera to see forward and display on bridge monitor. $169.00 for listed camera
See Sony camera attached: 150 feet in dark is not bad could save a collision.
John d
* Color Weatherproof Night Vision Camera with Sony CCD
* Sunsheild
* Mounting Bracket and Hardware
* RCA / BNC adaptor
* Manufacturers One Year Warranty
CAMERA SPECIFICATIONS:
* 1/3" SONY CCD Imaging Device
* Number of Pixels: 768H x 494V (NTSC) 752H x 582V (PAL)
* Scanning System: 525lines 60fps (NTSC) 625lines 50fps (PAL)
* Horizontal Resolution: 380 TVLines
* Internal Synchronization
* Video Output: 1 Vp-p 75 Ohm Negative
* S/N Ratio: More Than 50dB (AGC off)
* Gamma Characteristic: 0.45
* Automatic Back Light Compensation
* Automatic White Balance
* Minimum Illumination: 0 LUX
* Electronic Shutter: 1/60-1/100,000 (NTSC) 1/50-1/100,000 (PAL)
* 6.0mm Fixed Built-In Lens
* Power Consumption: 12VDC, 750mA
* Operation Temperature: -10 C - +50 C
* Weight Approx. 900g
* Dimensions: 83X131mm
* RCA / BNC Compatible
my house system is lucky if you can see something 10 feet away. But I got a hand held one eye scope thing, can see way out there, but its more of a when your looking for something. at nite if you want to have anything that works well your going to paid for it. and you get what you paid for.[:-eyebrows]
I understand there are systems, but i would like some night vision at a price i can afford. Sony night vision works as my video cam can see in total darkness. The listed camera 150 feet total darkness, several say 30 to 50 meters 100 to 150 plus feet. I have a sony camera on my RV that can see several hundred feet with very low light (sony camera) in zero light it cannot see very far. The sony's with infraed seem to be the ticket. My Garmin has a video input so if i got the right stuff, cameras, cable i could have a system for a few hundred bucks. Not like the real systems, but i think it might be worth the modest price if i do it right.
Any body do this?
John d
There are three ( at least ) types of "night vision cameras" out there right now.
a) "flir" types. There are long IR sensing cameras. Very expensive, and I'll stop there ( except to say, very desirable )
b) amplified video. These quite literaly amplify the received light. aka: starlight scope. They require -some- light, but do not need an illuminator. The ITT monoculars come to mind.
c) very sensitive standard video cams, with IR illuminators. Cheap. When the target is in range if the IR spotlight, the target is visible to the camera. Something like a movie camera with a spotlight, only it works with Infrared light to which the human eye is insensitive.
You are talking about a type "c" device ( I suspect ). Range is limited and I would bet that it would be useless for navigation.
IMHO
"but i would like some night vision at a price i can afford."
From what I've seen, pun intended, there is no cheap path to good night vision for navigation.
You are better off spending money on very good binocs with above average light gathering ability.
i don't think it's a good idea, looking at the monitor is goign to hurt your night vision and you'll be blind as a bat when you need to see outside.
I see far more downsides then upsides. agree with Pascal. Biggest problem at night is having your vision interupted with burst of lights. When running at nigh, Ido a lot of it. I insist on all lights eing off except red for minor use. Refrain from spot light use except as needed, and then quick burst. As stated by Capt Bill good binoc are worth their wight i gold.
Keep it simple, you are always better off.
Guess the question is why do you want a system that can only see a few hundred feet and in a narrow cone at that?
If your looking for a lobster pot or a head in the water, that may work. If your looking for other vessels you want a couple mile range and 360 degrees (32 pts for the "Old Timers" ;^) )
I suspect people such as Novemeber Charlie have more time running at night in coastal areas than most of us here. They usually only have 4 lights on, red, green, masthead and stern.
All I can say is that some units can be damaged if you open the lens cap in bright daylight. I think I would try a unit before buying.
I haven't had problems if the moon was out. I've had to run on instrument's alone when the moon was down. Take note where the moon is before traversing the waters a night.
Another night time technique is to use the city lights to establish where the shore is. Last month my buddy got pulled over in the SF Bay by the USCG.(Black patrol boat, bow mounted 50 cal, Black uniformed USCG Ninjas) While they were shaking down the boat, my buddy noticed a black shape (Occulting)the city lights. It turned out to be an approaching cargo ship, blocking the background lights. They mutually agreed to get out of there.
I have to question this a little, My GPS is on at night and it does not hurt my vision, the same tool would be used as a monitor so no vision isse there, i have a sony low light camera in my RV that can see very well in all but total darkness. I can see maybe a 1/4 mile with it where i would not see a hundred feet without. Field of view is not a issue as i see it, not a problem in RV several hundred feet wide at a 1/4 mile. 150 feet in total darkness would be nice when passing a bridge, radar will give me far away images, but this might be the answer for close up in the channel, under the bridge at the marina, just a little help, not daylight at night.
My question was do you think this would work, and has anyone done it, seems the answer to both is NO!
Thanks for the input
John d
I think the best (and certainly most affordable) "night vision" would be a blacked-out boat and dark-adapted, Mark 1 eyeballs. Turn on a spotlight and you've blown it.
From my understanding, night vision requires either:
1) background lighting (starlight, whatever) I don't doubt a "starlight scope" would help but I think it's utility is limited.
2) Infrared... the "target" has to be warmer than it's surroundings. If it's not (say a can buoy, post, or a crab trap) it's not going to show up.
3) Floodlit from the boat. Most "nightvision" cameras have their own IR LED's to light up the "target". If it's out of range of the LED's, it's pretty well useless. I have such a camera on my boat for rear-view vision. Daytime it works fine. At night, even when docking, forget it. My rear-view mirrors (yes I have them) work better.
I run at night almost as much as I do daytime. I stick to KNOWN clear areas and SO FAR I haven't hit anything. I have picked up a couple crab traps.... both in broad daylight. Bouys were gone, nothing to see. I also run slow enough that anything I DO hit won't cause any damage. Any other boat out there has lights, if not he's fair game!!!
In another life I navigated the world in large gray ships. Minimum required navigation lights and a very dark ship, especially the bridge, really works best. An alert skipper with a pair of highgrade 7 x 50 binoculars on the open bridge can't be beat. Works for sandpans,lobster pots, floating mines.
RIGHT ON SALTY!!!! Been there in big black ships... I agree 100%. In my younger days the only lights on the bridge were the compass and the coffee pot... and when the coffee pot kicked on we'd see the reflection in the bridge windows and grab our binoculars before we realized what it was. Talk about feeling foolish!!! But EVERY light had to be checked out!
Nowadays we have two radars and a gazillion other gadgets lit up... night vision is toast. But then we have the radars to do the seeing. Sure took all the fun out of it!!!
I have spent a lot of time on the internet searching for Night Vision Thermal Imaging products. I have found what may be the lowest cost product actually made for Marine applications. The Thermal Eye 4000M http://www.nightvisionstore.com/L3 Thermal Eye 4000M Thermal Imaging Camera.htm
Can pick up a human at 1500 feet come with pan and tilt plugs into video port on my Garmin and cost less than $8000. Thats a lot but if you boat at night it might be a good investment. Search for L3 Thermal Eye 4000M Marine Thermal Imaging Camera and you will see some great night shots.
Les could you think about adding this to your product line if there is good interest? So we could all enjoy the Boatfix discount. I will have a quote and full details today, but I have looked at this one on several sites and it looks good. They make a similar unit for land use I think it is the 4000C.
What do you guys think is $8000 maybe less than $7000 too much to consider? Maybe less if Boatfix was to add same.
John d
Here is a few additional pictures of setup http://www.morovision.com/thermal_imagers/4000m.htm
willie nailed it ! thermal infrared works by imaging temperature. that log or crab pot isn't going to show up...
when you say "My GPS is on at night and it does not hurt my vision" how much do you dim it ?
the only thing i'd consider may be a pair of "low beams" at the bow, aimed low not to bother anyone and jsut bright enough to pick up something at close range to take evasive action...
You got your facts wrong on the log showing up, it will and anything else study the system they even so a log on one of the sites. Log, aid, person, what ever. This is what the tool was made to do. goto this link to see 2007 night vision is all about side your mouse per instructions
http://www.morovision.com/how_thermal_imaging_works.htm
John d
well.. i got my "facts" from the link you posted...
"the Thermal-Eye 4000M offers state-of-the-art infrared thermal night vision"
thermal means it's using temperature differential, seems to me that a crab pot buyo will not be much warmer than the water it's in.
it also says...
"Thermal-Eye 4000M Characteristics.
• Provide the powerful advantage of sight in the dark
• Detect unauthorized or unwanted intruders
• Monitor perimeters of restricted facilities, night or day
• Quickly scan between homes, buildings, dark garages, alleys or even
under vehicles
• Identify lost boaters or stray objects on the water
• Observe prowlers and criminals without their knowledge "
sounds to me like it's a security device, to detect intruders, that they are trying to sell boaters... great for S&R but not to avoid hitting .
see the link they have explaining thermal Imaging and light amplification... light amplification will let you see a bouy or log, not thermal imaging. or you'll be spending so much time with your nose glued to the scree that you will not see the properly lit vessel closing in on your stbd side...
"150 feet in total darkness would be nice when passing a bridge, radar will give me far away images, but this might be the answer for close up in the channel, under the bridge at the marina, just a little help, not daylight at night."
one more thing... if your lights and electronics are dimmed, you will see the shadow of an unlit marker at night, or a bridge... your radar can help too, just set it to a very low range, like 1/4 mile and you will see a lot of things !
how much night running have you done ?
Take some time a read a little 1500 feet to pick out a body, not 150 feet. This is not the camera i started this link with. The 4000m is a marine unit 4000c is security. i am not a expert, but there is plenty of info to explain how this works, however I am sure if you take your normal study on the topic you will figure why it will never work for you and like minded folks.
Learning about this is not a 10 minute read, unless you are so gifted you already know everything on the subject, then reading and looking is a waste of time. I can understand why most folks would not want to waste time.
However i am a rookie and this is all new to me, so i read on.
John d
