NO GIN ... updates
Well fellers I couldn't wait to show off my new help. It's not quite complete but almost there!
Thanks! I'm happy with it. I will post more pics as I finish. Was hoping for nice weather this weekend so the wife and I can nail down the final prep coat and slap on some paint.
Looking good, what are the steps you used?
Looks like you laid in some glass mat, then covered with Fairing filler and epoxy/ Is there another layer of glass in there? Did you paint for the white or is it gel coat?
I laid several layers of glass to get about 1/4 inch thick. Then used a heavy marine filler for about 4 layers then a light filler for about another 4 layers. All along sanding and smoothing out. The white you see in there is a 2-part epoxy primer from Interlux. Put 2 layers of that on then filled in small voids where needed. I wanted to make sure it is very strong and also very smooth looking. I still have some final sanding to do with a 220 or lighter grit paper followed by some more primer. Then onto the painting. Think I am going to stay with the Interlux Briteside white but use a flatening agent to slightly reduce the gloss.
I didn't post all the pics through the steps. Trying to figure how how to post my slide show so you don't have to scroll down through tons pf pics.
fantastic job. i don´t care much for the new steering wheel, but that´s just my opinion. the rest is a tremedous improvement.
Since my shift cables will not be in till sometime early next week, I decided full steam ahead on my helm and topsides! I removed all the gauges and switches and started the final prep for paint. I sanded down spot skim coat of filler and smoothed out the first 2 coats of primer. Tomorrow I will lay one more layer of primer. Hopefully by tomorrow night I will be able to sand smooth and lay down a coat of paint. I am still not sure what color to go with though.
At the same time I am putting the wifey to work giving the topsides a quick surface sand to level it out for the primer.
One of the problems with windshields is glare/reflections from objects on your dashboard. Darker colors reflect less. I stuck a dark gray carpet up there. It also helps preventing things from moving around up there.
That's a good idea. So sticking with the Briteside white with some flatening agent to reduce some gloss would be fine as long as I can figure something out for the top of the dash.
Hope you are still there Charlie... what do I do for a proper christening of NO GIN so my problems stop?
Find a good mechanic you can trust and let him go over the boat. I have reservations that running the enigines with low water flow has done serious damage to them. You may in the end find is it less expensive to replace the engines and call it a learning experience.
Hi Charlie. I can appreciate this advice however what would a mechanic check for when coming on board and how would he do it?
I only ask because I am feeling comfortable with everything and also have access to tools like a compression tester, pressure tester etc.
Thanks.
Of course we had a beautiful day today but I couldn't spend it working on her due to prior obligations! I still managed a couple hours prepping the topsides.
I am going crazy with deciding the color scheme. Originally I wanted to just go all white. Then I saw a boat that had an over sized champaign stripe than ran bow to stern. But I am not sure if I like any of the champaign colors offered by Pettit or Interlux.
Any opinions for me??
Well I went ahead and bought a gallon of the Interlux Brightside White today so I guess it's going to be white. I figured If I wanted to go and add the champaign stripe later on it would be easier going over a smooth white base. Now if only I can have mother nature give me a few nice days!
As per Interlux I also bought a quart of pre-kote for the areas that need to fill cracks, scratches, nicks and minor imperfections. Other than that the previous Brightside coats will serve as a good surface to paint over.
NO GIN, I was a little wary of you at first when you said that this was your first boat, but you had another one for sale... BUT after reading your response and knowing the full story and now seeing everything that you have done with your Thompson I am happy that you are on this site and I am hoping that your boat turns out well. It is nice to see your enthusiasm and willingness to learn and save yourself a couple of bucks in the process. Keep up all the good work and be sure to include a lot of photos of your progress.
Thanks for the support and kind words. I can see where someone would question my integrity as I came on pretty strong right off the bat. However, that was just because of my true passion for my boat and many concerns of what I did to her.
Today we continued prepping the hull with 80 grit sandpaper. I have to say that the current paint on the boat was applied absolutely incorrectly and is taking us a ton of time to sand through the many runs, tiny bubbles and waves. However I am confident that after sanding enough down and pre-koting it the final 2 paint layers will show a brilliant and smooth finish that I can not wait to show off!
I've been following this thread right from the beginning too and it just seems like there's ALOT of WAY TO MUCH work all being done way to fast.
The thread is getting old real fast and I personally don't think that one guy can do all the work claimed to have been done and still run a business and etc. etc. etc.
I think Bob is yanking everybodys' chain.
Fist off swabby you have no idea what the "F" you are talking about. My name is Joe not Bob! I am posting pics and updates of everything I am doing... not good enough proof for you? Come to my house and see! I am highly motivated and when I set my mind to something I do it!!
