No water at faucet
Brian
Connected the dockside water today everything ran fine but then the faucet at the kitchen stopped. All the other faucets ran no problem. Just something blocking?? Took off the strainer cleaned it but still no water. any advice
If the strainer was cleaned, I would have to think a faucet problem next. BUT First bilge dry?? Do you not have either, hot-cold? Did you winterize the boat, or a tech ?
Dusty it was winterized by a tech. I have a faucet after the kitchen faucet and one before . they both are working. I guess this weekend I will take it apart and see what I can see.
Sounds like it's plugged-up internally, or that some internal part has broken - or frozen. Taking it apart should let you know for sure, one way or the other.
Sometimes during winterizing, they'll miss a faucet. They forget to open the faucet and let the pink anti-freeze run out, allowing some residual water to remain inside the faucet, where it freezes and breaks something inside it.
Taking it apart and examining it is the only way to find out for sure.
start with the easy stuff, pull the areator off the end of the faucet dismantle it and clean it out. a little bit of sand in it will blcok it up.
