Noisy air conditioners?
Ted Williams
We have three Cruisair rotary AC units on board (about 10 years old). Two of the units have developed a really bad sounding compressor noise. Kinda like a combination of a rattle and a buzz. It's worse when it initially starts up and reduces a little over time.
Really annoying as both are located under seats in the salon. There's not much room for adding any insulation.
The dealer says that "just happens with rotary compressors". At this rate I'll be glad when they finally just give out completely. Are they in the last death thros?
Has anyone experienced this and had any luck with abating the noise? Maybe adding a lubricant to the charge? I assume replacing the compressor is about as expensive as replacing the whole unit.
Thanks, Ted
I found my cruisar unit was rattling against itself. Apparently there are litte rubber gaskets that wear out.
I opened up the intake vent hatch and just by touching around while it was running I found where it was rattling and i wedged some new pieces of rubber in there. Made it alot quieter.
Not sure if that is your issue, but check it out.
I have felt around all the pipes when it's running but have not found a place where it's rubbing together or touching. I can see it only from the top and can't see from the sides or the bottom. I will definitely check it out again when I'm down there (with a mirror). It's possible there are some rubber feet on the bottom that have worn through. Thanks for the suggestion.
Sounds like the compressors are going bad. But check the freon pressures too.
You can add oil, but it won't need any more if you never had a freon leak. If you had a leak
then some may have come out but probably not enough to make noise. Some compressors make a
lot more noise than others. There is not much to do about it.
You can check the rubber feet on compressor mounts. They may be too tight. The nuts do not
have to be tight. If too loose, that can cause noise also.
3 compressors under one seat?? gee...
any boat big enough to require three air con should have remoted compressors in the ER!
i've never been able to match age and wear to noise when it comes to compressor. I agree with the other comments above, check the rubber mounts first.
Compressors like any motor do wear with time. All good info above....
Pascal he said 2 of them are located under the salon not all 3. When I purchased my boat it had 2 16,000BTU units they barely worked. I repaced them and the new AC/Heat units and digital controls draw less current and do their job much better than the original units. I even had the old units services but noise wise it didn't help much. Last year I had a strange problem with the Salon unit, it would sometimes lock up and grunt and groan it ended up being the main breaker being bad that the salon AC unit was on. I had both of the panels Main breakers replaced. Sometimes low Voltage can be the problem the key to finding my problem was trying running the Salon AC unit on the generator it worked great there but not on shore power because of the breaker.
Good information! Thanks all.
Pascal, I wish the compressors were in the ER, one is under the bed in the aft cabin and the others are under opposite seats in the dinette. Those two blow air into the salon and the forward cabin.
I'll check the rubber mounts and see if that helps. It may be a week or so before I can get back down there.
Again, my thanks to all for your helpful suggestions.
