Norcold Parts
36mainship36
Running very well ( Knock on Wood ) Old DE821 Refrigerator 1985 vintage. NEED DOOR PARTS. Checked usual sites, no luck. can anyone help ??
Lou R.
James, I need hinge parts for lower door. The frame where the pins are positioned cracked and now the door will not close without help. I can get model # if that will help.
Lou R.
36 Mainship D/C
I was surprised when I wanted to purchase a door gasket for a Norcold. The gasket was only available with the entire door from Norcold. My choice was to cut a generic seal to fit or defrost more often.
I have a good door seal on my marine refer. Seems like I defrost it weekly, and it is not opened frequently. Has anyone ever bought one of those battery operated (as in flashlight battery) circulator fans for their refrigerator ?
I might have the chromed/stainless hinges from that particular model. If thats what you need, and I can find them, there yours.
When I said " hinge" , I should of been a little more specific. There is a plastic frame that holds the door panelin place and also is used to hinge the door. It is held on by 4 screws on the top. This is the part thats broken. I may have to resort to epoxy. Last resort. Let me know if you can help.
Lou R.
Your gonna need a new fridge soon enough. I think this is your fridge's way of letting you know it's time. Come on you know you want a nice new shiny fridge.
I have one of those fans and it drops the temperature about 5 - 10 degrees in mine. As long as I replace the batteries every month or so and allow for good air circulation it makes a big diference, especially in hot weather.
Where go you place this batt. operated fan you guys are refering to. I was going to install a fan under or right behind our fridge, but haven't got to it yet.
My new Norcold DE0061T had a large computer (muffin) fan blowing accross the back coils if the frig. The old one I pulled 3 years ago still worked it was starting to show it's age and rust near the bottom it had no factory installed fan.
Thanks for all the replys. I was able to reset the hinge pin. 5200 to the rescue. Reset pin and backed up cavity with 5200. So far so good. Allows me time to research a replacement unit. Good winter project.
Lou R.
I am talking about a small circulation fan that goes inside of the fridge. I think I bought it at an RV place.
I have done both, coil fan and fridge fan. Both make a huge difference. ANd I use a digital temp gauge that mounts on outside with ribbon cable to sensor that goes on the inside of the fridge. Great peace of mind, especially on extended trips. No need to open fridge to see the temp.
After switching from the original Norcold to the new DE0061T I have seen a big improvement over the older "1993" unit. I run mine on 12 VDC all the time. The current draw is less than 3 amps when the compressor is running and the freezer frezzes and the frig stays ice cold. I have seen many posts about the "NOCold's" but that is not my experience with the newer unit. I have had it 4 seasons now and it only gets shut off when I winterize the boat in mid December through April 1st. I have never had to defrost the new unit.
I am glad to hear you were able to fix your unit.
the voltage to the compressors on the DE828 is 24 volts AC but it oscillate between +24 and ground ie 0. You can attach a 12 volt DC Muffin fan to this voltage source and it will run fine, turning on when the compressors operate. Use the fans to cool the condensor coil behind the refrigerator and you will greatly extend the refrigerator lifetime and increase its cooling capacity. I done this to my refrigerator (I use 2 fans) and it works great (10 years and counting) Every 3 years or so I have to replace the fans--they cost about $15 at radioshack.
