My mechanic rebuilt my upper unit and he lake tested the boat today. This was it's first time in the water in 2 years. He said shifting/unit was great but he experienced some 'fuel starvation type symptoms' right as he took it on plane and took it immediately back to the dock in an attempt to keep from being stranded. Here is my plan. Please tell me if you think I have left anything out and/or are doing something stupid or overkill. For what it is worth I have always used StaBil marine stabilizer.
1. Disconnect the fuel line from the tank and drain all that I can.
2. Change the fuel separator / filter.
3. Possibly replace the rubber lines (but will probably just drain them out).
4. Drain the float bowls of the carb (Holley 4160).
5. Clean all surfaces and orifices of the carb that I can get to without removing it.
6. Not related - but - Oil Change
7. New gas in the tank.
Is there something I should check without going to this trouble first? Easier way? I appreciate your thoughts and comments.
