NYC trip advice
eahearn
Hi, I am planning a trip from Narragansett Bay, RI to NYC, for this Summer.
Since all our cruising to date has been around Naragansett Bay (Block Island, Cuttyhunk, Vinyard), I would appreciate any advice anyone with local experience might have.
Our boat is a late model 36' Silverton Convertible, gas engines, capable of approximately 18-19 kt cruise speeds.
Given that this will be our first time in the area, my plan is to be relatively conservative on number of miles for each day and to make two stops along the way.
I'm thinking:
- Tiverton to Westbrook, CT - 65 mi - assume 4.5 hrs
- Westbrook to Northport, NY - 48 mi - assume 3.5 hrs
- Northport to NYC (Liberty Landing Marina) - 45 mi - assume 3.5 hrs
My time estimates include time for gassing up, no wake zones, etc...
My plan is to stay north of Fishers Island, entering through the Watch Hill Passage. I've heard it's a nice passage, looks well protected and keeps me away from The Race.
Questions:
- Marina or mooring recommendations in the Westbrook, CT area would be appreciated.
- Hell Gate - the tidal flow numbers are attention getting. My plan would be to time this part of the passage so that I'm going with the current. How is it going through Hell Gate in a power boat? Is the current relatively uniform or are there lots of eddies that move the boat off course? It seems pretty wide, so even if it does, I would think it wouldn't be too bad.
- NYC - how strong is the current in the East River. Anything I need to be aware of in this area as well as rounding the lower tip of Manhattan Island?
- NYC Marinas - it looks like Liberty Landing is the only real choice for NYC. Any feedback?
- Anything else I'm missing?
Thanks, Ed
You can get through Hell Gate easily in a power boat, however, when the tide is running hard, you can get some good sized swells and eddys. The East River current runs out very quickly, again, big swells at max ebb.
Once you get down around the South Street Seaport and around the tip of Manhattan, you can expect plenty of ferry traffic, throwing off wakes in every directionl. Keep your eyes open and have the crew hold on.
I would recommend Cedar Island Marina in Clinton or Brewers Pilot's Point in the Westbrook area. Both are very nice.
You should try to plan each day's run going with the tide to pick up some mileage. Remember for winds, "west is best".
LL is probably your best choice.
Get yourself a copy of the cruising/waterway guide for the area.
Ed,
No suggestion about a Marina in CT
Hells gate should be no problem with a power boat like yours, as far as going with the current or against, my personal preference is to go against.
East River, been there a handful of times so not an expert, but don't see any issues.
Although there are other choices for Marina's from what I am told Liberty Landing is the best choice (protected).
I believe there is a water taxi to take you over to NY
There was an extended discussion of NYC marinas on another forum and the point I took away from the discussion was that these marinas are very expensive. Not only $6.00 per foot or more, but lots of "surcharges" that I thought would have been included in the base rate.
I would look them up on the web or call them before making plans. Now if money is no object ...............
Liberty Landing is $4 a foot daily and $19 a foot weekly which for the northeast is not bad. They do add a daily electric charge but again that's typical for the area. It's a nice marina with great views of the city and a water taxi right from the marina and is where I always stay when going into NYC by boat. Only issue is that the water taxi doesn't run late but when we were there in September the one night we stayed out late in the city we took the PATH train to NJ and then a cab and no issues (and about the same cost as the water taxi).
All good input so far - keep it coming!
Believe it or not, I had narrowed it down to Cedar Island or Brewer's Pilot Point, based on my research so far. $4 a foot is pretty much in line with what we pay at other destinations in our area, so it actually doesn't seem so bad. And, as Walter said, it does seem to offer the most protected marina option - which is good. Interesting comment on running against the current at Hell Gate - I had been planning to run with the current in order to maximize speed but running up current should be more controlled and would appear to avoid the swells at ebb noted by Hogan, at least on the trip to NYC. I'll have to replan this part of the trip.
- Ed
- Ed
- Ed
not why you would want to run against the current at hell gate... with a power boat, if you have the current against you it's no big deal but if you can you may as well run with it. i've been thru with both, sometimes at max flow, and it's just a minor chop. I think "swells" is too strong a word there. either way, i dont' think i've noticed a difference in chop.
non issue unless you're in a 7kts trawler or a sail boat.
passing north of Fisher is nice, you could stop in Stonington or Mystic (both are pretty nice towns)
I really like stopping at the Thimbles (nice anchorage, very scenic), in your case you could do a lunch stop there
I've made the trip up and down the east river many times. Hell Gate will not be an issue for you. Pay attention to the barge traffic especially around that area since it is a bend in the river. Biggest frustration is running against the current in the east river so time your trip to go with it. Otherwise it will feel like you are plodding along.
Never stayed there but have heard good things about Cedar I. Robski stayed there last summer and Giolic (sp) keeps his boat there I believe.
As mentioned, and I am no "Captain" like Pascal, my personal preference is to deal with a current head on. Just like I like to deal with waves.
I am speaking as a novice, always feel more comfortable with a sea off the bow than a following sea, same true with a current.
Just me and my limited experience.
I try to plan to travel with the tides not against them, I see no advantage to fighting the tides. Travel faster better fuel economy, I'm not sure what I'm missing. As for Hell gate I try to hit it at slack tide but in my current boat I don't give it much thought. The Battery is tough with an incoming tide in addition to all the traffic but it sounds like he is traveling in a good size boat and should have no problems as long as he is aware of the condition my face. I'm know I read a recent post some where about another marina in NYC that takes transients it sound interesting and I was thinking I might try it. I'm trying to find the thread it was on an other forum but if I can find it I'll post the info on the marina, although I have only heard great things about LL I still like the idea of being in NYC and not having to deal with the ferry.
I knew I would find it, does anyone know anything about this place? Looks like a nice stop a bit pricey but it is in Manhattan.
http://www.thenorthcove.com/
Think about pulling in a little before Westbrook at the Connecticut River. Essex Island Marina or just drop the hook off Essex. Hamburg Cove for a sheltered mooring. Some nice marinas at the mouth of the river too, Saybrook Point.
Dave, I walk past North Cove a lot and it's not very sheltered. There's only a small amount of dock space for smaller boats (it's mostly setup for big yachts) and the ones that are there are usually rolling all over the place when I've seen them from the wakes coming into the basin.
Liberty Landing marina
Notice what is in background to the right.
North Cove seems very nice - if I could be right in NYC that would be optimal. I'll check availability...I'll check out Essex area too.
- Ed
Whoops, I spoke too fast - I don't want to be rocking and rolling. Maybe I'll just stick with Liberty Landing.
- Ed
Liberty Landing is, by far, the best choice. Port Imperial finally gave up due, in part, to the tremendous wave action from passing commercial boats. Linocln Harbor gets some wqave action also. The ferry into Manhattan can be more convenient than docking on the Manhattan side.
If you have the luxury of timing the Hell Gate passage, why not go for slack water? The standing wave and swells aren't the problem. Getting crushed against the seawall by a barge could make a bad day. At max ebb, control can get dicey.
Once you're in NYC waters I don't think there are any no wake zones. You'll be busy watching for jetsom like 12 by 12 chocks off commercial vessels. If yu pass after major rain storms, there will be incredible amounts of stuff to dodge.
watch for rocks north of Fishers and in the Thimbals. No big deal but you do need to stay alert.
Lincoln Harbor defines rock an roll.
LL is without a doubt the best. Liberty Harbor is an alternative marina across the canal from Liberty Landing and might be closer to more restaurants on the Jersey side. We have yet to use it but we have heard a few good stories. If I am not mistaken the train is on that side of the canal. However, the view will much less there.
As far as Hell Gate goes, there is a Con Ed power plant there and when it is cranked up good the discharge of cooling water can give you a shove to the West. We passed by it once after a power failure at about 8 knots and wow was that a surprise.
Don't forget to stay clear of the U.N. security zone and also keep clear of all large Ferries and passenger ships (more homeland security mandates). Going around the Southern tip of Manhattan keep an eye out for the Large ferries departing or enterring their terminals. Keep your radio on scanning 9/13/16 and listen for announcements (you might actually understand a couple).
