Occasional WOT
MarkMuck
We have 1999 502 Crusaders. We do most if not all of our running at 1800 t0 2000 rpm. My friend says you need to let those motors run at WOT every once in a while. " It' s good for them." Any opinions on this ?
Mark
Mark, have the 454XL Crusaders in my '93, 37C. Since new I have run at WOT for about 250 yards when approaching marina; then back down to idle speed at No Wake Zone. Doesn't seem to have hurt anything. BTW, I generally cruise at 3150 rpms.
Setting up to reach WOT and occasionally running at WOT for short distances is the simplest way to determine that your engine is putting out full power.
Based on your profile, I would think you are killing them. Unless your 34 foot express has a super secret hull design, at 1800-2000 you are above hull speed but not on plane. Bringing them up to WOT every so often is not going to hurt. It is a quick check to see if your props are still in good shape.
My 2 cents
Agree with David, at 2000 rpm you re just pushing a big wake and overloading those engines, it s just about the worst speed you can run at... Either you run on plane or you run at hull speed, fully settled which should be around 7 to 7.5 kts for a 35 footer
I do not know that I ever actually get to the firewall, but I frequently will run for a short period well over 4,000 rpm. My normal running rpm is 3,000 to 3,300.
I agree that 1,800 to 2,000 is probably one of the most inefficient areas to run with your setup.
G
Check the manufacture specs for your motor, Crusader recommends running the motors at 3/4 WOT for optimum life expectancy.
Ditto to the above posts
The only way you are going to tell if you have a problem with either the running gear, motors, fouled bottom, etc... is to run the boat at WOT and hope you get it there.
You will not hurt the motors to do so, they are made to go that fast, plus you will help blow out all the carbon and crud that is built up in the fuel system, the heads and cylinders and clean up the spark plugs.
Running at 1800-2000 RPM's is lugging those motors, you are doing more damage than you think. Run them at 3200-3400 rpms and they will be happy.
Your engines are designed, and built to accommodate the full range of speeds. This includes periodic operation at WOT for short periods of time, under load.
I try to run for a few minutes at WOT once a trip, just to make sure all is OK, but 90%+ I am at 3/4 or hull speed
I should have updated my profile. We now have a 99 Silverton 392 Aft Cabin. We don't have
the 34 any longer.
Once a month I go wide open .... 60 gph and 3-5 mph increase is all I get ....
She does reach WOT of 2650.
the 34 any longer.
well same thing maybe even worst with a heavier boat! You dont want to lug those engines at the wrong speed. At anywhere between hull speed and planning speed you re burning as much fuel as on plane for a fraction of the speed anyway
A wise surveyor told me to go WOT at least once per trip, preferably as soon as possible when the motors are nice and warmed up. If you have any troubles, you will know at the start of the trip, hopefully not in the middle.
Personally, I don't think it's ever actually "good" to run them at full WOT after proper break-in, but it's a necessary evil to detect whether the engines are propped correctly, reaching well into the mfgrs's WOT range spec., plus allowing the operator to detect whether a noticeable reduction in attainable WOT has occured demonstrating a need to figure out why.
I only do it about twice a season and only long enough for RPMs to steady at max level. If something wants to break loose, wear or clog it's a lot more likely to happen at 5000 rpm than 3400. I always feel like it probably takes another 100 hours off the life of both boat and this owner.
Not sure about the Crusaders, but imagine their spec is close to Mercs of 4600-5000 rpm WOT. With a heavy boat especially, I think you would do best to make sure your props are sized to reach at least 4800-5000 rpm. Crusader recommends cruise rpm of around 75% of obtainable WOT, though many of us cruise a bit below that for sake of NMPG economy.
FWIW- I just looked up an online ad for a Silverton 392 that claimed cruising speed of 20kts/ top 26kts with 454's.
I usually do it the first launch of the year and the last launch of the year. It helps clean out the crap leftover from winterization, let's me know that all is well and will signal something wrong. At the end of the season, I do it again to double check the rpm's. If something's wrong, I can work on it over the winter.
1800 to 2000 rpm is the WORST gas mileage for most gas boats plus it pushing a huge wake that everyone will resent when you "plow" by!
My boat's owners manual suggests running at WOT every once in a while to see if the bottom is clean or there's any other problem (it's a diesel).
There's seldom a need to run WOT for hours on end. However, running it at WOT for a few minutes is not going to kill the engine. The engine was designed to run at maximum rpm's and should be able to reach it if everything is in working order. If not, they would reduce the max rpm's. Lugging the engine(s) at 1800-2000 rpm's is not doing it any favors. Get the boat up on plane where it has last resistive force. Many gas boats run 3200-3800 rpm's at cruise.
