Oil drain Hose
pequad1
I have a 04 BayLiner with the 3.0 Merc. It came with the oil drain line that goes out the stern bilge drain hole. I am having a hard time getting it out. whats the trick to it? Also how hard is it to get back in. Or when I drain the oil should I just go threw the dip stick with a hand pump?
How cold is the drain line and is it original? If it is original, a lot has changed with regards to pliable rubber. The newer ones I have seen are braided stainless over fuel resistant rubber. If it is still cold in NJ, try hitting it with a hair dryer. My cousin in Jax, FL made his own long before Merc introduced them. He loved it. Never a problem with getting it out the drain hole of his Bayliner. However it was usually above 70* when he used the system.
HTH.
P.S. I wish I had these on Saint Max. I would love to be able to suck the oil from a low point in the pan as opposed to sucking it out the in hole.
If you have a hand pump, you should be able to attach it to the oil drain line and pump the oil from there instead of the dip stick tube. That's what I do with my Oil Boy and it likely gets more of the oil out than using the dip stick tube.
I have the same on my 04 SR, it is attached to the drain plug with small cable and a swivel, it is a little difficult when the cable is frayed and sticking the fingers working with it, just changed may cable. If you do not have the cable it is going to be more difficult, as in PITA, if no cable look at the 2 plugs there should be holes in them you can put the cable in. Make it up with a swivel using the leader make up connectors and cable. Putting back in you just push it in. Be sure to warm the engine before you try to drain, warm is much faster drain.
Sometimes mine gets kinked up and I have to crawl into the bilge and feed it through a little bit. Sometimes, I get my 11 year old bilge monkey to help.
