Oil In Bilge
carver 2557
This morning I turned on my bilge pump to see if there was any water in the bilge...We always get a small amount of water in the bilge after a heavy downpour as it comes in the vents on the side of the boat.,not a big deal...I bilged about 3 cups of water out, and when I looked into the water it looked like an oil ship had dumped his load of oil...As we know it doesn't take much oil to look like that...It apears that the oils is entering into the bilge from the outdrive where the shaft goes from the engine to the outdrive...There is a mix of oil and water under the shaft...The engine oil and all other levels of fluid are ok as far as levels and no other leaks anywhere...
Obviously I have water entering the outdrive, but am wondering why it is running out the top where the shaft goes into the engine...Is it possable that the outdrive is taking on so much water that it is overfilling?...
I am going to have the boat taken from the water this week and am looking for advice on what to look for...
Outdrive---Mercruiser Alpha One (New from Mercruiser 3 years ago)...
Year-------1989
Engine---5.7 Litre Mercruiser
Check to see if your outdrive oil reservoir is low or empty, if so I will tell you more, if not check you engine oil. First step is to locate which of the two is dumping oil.
I dont have a visable outdrive oil reservoir...The only way to check the oil level is to remove the boat from the water and drain the oil to see how much oil is in it...The engine oil level is good as I did check it...All other fluid levels are toped up also...I am suspecting the outdrive as it looks like it is coming from the engine shaft that goes to the outdrive...
are you sure it's no oil from the engine leaking from the rear shaft seal? that woudl end up in the same location as coming from the drive...
Not familiar with bravos but i think that's more likely, especially if the engine is older...
He checked oil level for engine and that was fine.
Outdrives are known to build up pressure over time and blow out the yoke seal, which then causes oil to come into bilge.
well, it doesn' take a lot of oil to dirty the bilge and leave sheen on the water... often without seeing drop on the dipstick, at least over a short period of time.
when you get a leak on the input shaft of a bravo, doens't it get into the bellows? at least on my old Volvo that's how it was, then it woudl have to pass thru 2 seals before getting into the bilge...
I don't know alot about it other than when the yoke seal lets loose, the bellows fills up and the oil begins to come into the bilge. Its not a little oil, its a lot.
Carver,
Is it a lot of oil and you are sure your oil levels are good in the motor? If the answer to both those questions is yes, then I would follow Current Sea"s lead on this. Only other place I can think that has oil is trim tabs, or Gen-Set, may want to check them also.
There's a weep hole starboard of the drive shaft and a little lower. You should be getting oil/water from that hole before the drive shaft. There is also an oil/grease seal between the gimbal bearing and the engine compartment.
If all there is is a sheen, chances the oil leak is light but put some paper towels on the surface of the water in the bilge or mop up the oil from the bottom of the bilge. You should see some type of color that would help ID the type of oil and where it came from.
Oil can also come from a leaky hose connection for power steering cooler or engine oil cooler.
Did the haul-out today and it is the outdrive...Drained the outdrive and the oil is a creamy miky color, same as I am seeing on the shaft from the engine to the outdrive...Our boating is basicly done for the year and we may only go a mile or 2 to have a swim 2 or 3 times, so I drained the oil from the outdrive and put new oil in along with a couple of new washers on both the drain and vent plugs...I did notice that the drain plug was not as tight as it could have been so this could be where the water was getting in...I checked with my mechanic and he says that it will be ok until the end of the season as long as I dong run the crap out of it...We will be hauling out and winterizing within 6 weeks, and that is when the mechanic is going to take the outdrive and do some tests on it to see what has to be replaced...
Milky oil? Isn't that an important 'symptom' you left out?
Do you have any idea how long the drive oil was contaminated?
Don't let the mechanic kid you. Unless he feels like the damage has already been done or expecting a bigger payday in the future. The high performance(green) drive oil is supposed to lubricate better if contaminated with water, the fact remains that water interferes with the lubrication. That's what is the killer in the drive gears and bearings. Rust is not...unless it's been sitting for some time. In either case inspection of the gears and bearings for bluing should be done. Gears get extremely hot simply by the friction of turning. Bluing happens when steel gets somewhere above 500*.
Here's a hardening and tempering chart with corresponding color indicators of color.
http://www.unionmillwright.com/2888.pdf
Oil lowers the friction and keeps the temps down. Bluing colors indicates a somewhat softer steel which allows for wear. Broken drives have either fractured gears or gears that look like they were made of cheese by the way got worn off.
The good thing, It's now cheaper to buy aftermarket drives than it is to repair them.
