Oil
dritter
What oil do you use in your engine? I have a 1988 mercruiser and used 40w in it this year. Some people say that I should use the mercruiser 25w 40. Is there any advantage?
why do folks think that any of us would know more than the engine maker about the best oil for an engine ????
I don't know guys, but he asks a valid question. My Crusader manual calls for straight 40 wt oil however, my Crusader dealer recommends Mercruiser 25w - 40. I follow the dealers recommendations as I'm not in a warranty situation anymore.
Greg,
Exactly!! My manual calls for 10w 30 or 10w 40 depending on the climate. Some techs say to use straight. I have used straight 30 and 40, but was wondering if I should use something different since it is an older engine. Someone just said to use the straight Rotella oil.
Does Mercruiser make oil??? I use Mobil 1 in everything I own. If I don't know what to use, I go see my Mobil 1 lube center for info. I have never had any problems.
It is really easy. Independent of brand every maker specifies a particular set of oil performance qualities. Any brand that meets those specs is what you should use.
Well i look at it this way. Rotell oil is made for rugged and tough truck engines so i figure it should be good for a boat engine. I use the rotella 40w with no problems.
SAE 10w40. Whatever is on sale for the best price. I don't go to FORD and buy thier overpriced oil either. 120,000 miles on my 1996 F150.
