Ok, so why so much HP?
Well-known member
Ok, so I ran down to the boat today to work up a BoatFix order and I spotted this in the slings
Notice that this is a perfectly flat bottom boat, maybe 24' long with a 150HP outboard offset to port. So you think it will fly?
My guess is the horsepower is for towing, not speed. Perhaps the engine is offset for side/saddle towing boats off the side. Or working nets off the starboard side. Hey those seiner workboats always drive in circles anyways, now I know why! :-)
Hey, there's room for another 150, imagine what 300 HP will do for that boat!
It looks like a no frill work boat. That HP will come in handy moving boats around the marina or holding pilings.
Though I can't say exactly what this boat is used for, flat bottom skiffs and garveys are used for anything from clamming, lobstering, gill netting, and line fishing. When I was a clam digger many years ago on the Great South Bay many of the diggers had over powered flat bottom boats. My 19 ft skiff had a 115 HP Evinrude, just about right for my purposes. When you put that much HP on a flat bottomed boat, at speed, in a turn they will slide sideways considerably, kind of like skiing, very fast and lots of fun. I'm not sure why the engine is offset, maybe he’s got another to go next to it.[:-crazy]
Saw a boat with offset motor in Conn. The guy had traps on the boat. Hed launch them off the stern. Single handed boat operation.. No idea how he retrieved them ....
Turning to stb at speed must suck .... ( actually turning in either direction could be dangerous ( at speed ))
There are a lot of commercial fishing boats in our area that put the engine on the side.
Oyster boats need a higher HP for the weight it has to haul, not for speed.
Conventional rotation single offset engine should be mounted on the starboard side.
if you look closely you'll see the wheel is a very low pitch for that configuration, no doubt its used as a work boat for pushing or pulling something.
