Old fashioned windscreen wipers
Karel B
  • Anyone know where I can get replacement blades or rubber thingies for these? They are 20" (500mm) and are off a 1980's American Carver. I live in the UK but have had no luck tracking down a pair. I need two.
    [image]http://www.sweetheartfilms.com/images/carver/windscreen_wiper_1.jpg[/image]
    [image]http://www.sweetheartfilms.com/images/carver/windscreen_wiper_2.jpg[/image]
    Cheers!
      ______________
      ________
Check this sites online boat store.You may have to replace the arm and wiper blade to a newer model if your size blade is no longer available,or try the manufacturers web sites,AFI,Atwood,etc. Or give Ebay a try. Cheers!
it proved to be a major hassle for me to get similar wipers of the right size up here in Canada, ultimately I found I could just pop in car wipers from the local automotive store - this was the one application where car parts on a boat made sense for me! cheap, longer arms, hinged ends on the arms, all made for way more capable wipers anyways...
Orcbait
Thanks yzer, but there's nothing there that's 20".
Maybe I should find a place that does parts for trucks and see if there's anything I can adapt. Was hoping someone here might be able to save me some trouble.
Man, why is everything to do with a boat such a hassle. in my next re-incarnation I'll hire!
Yup, just replaced both of mine on my 86 Sea Ray
Exactly like your's
Local boat dealer, didn't seem to be a problem, They had them in stock.
You replace as 1 unit, blade and metal in 1 piece.
They were about $13 each
The blades are easy to cut to fit as long as you get something that will mount correctly.
If your wiper isn't already Automotive replacement compatible, just get a conversion kit. The easiest was an asapter to turn the 1/4" motor shaft to accept the larger diameter auto wiper assembly.
Try to get a pair of these relatively new silicone wipers. They do a much better cleaning job.
G
Karel I just went through this with my boat. I went to the auto parts store and bought reg blades and popped the middle out of the new blade.There is a plastic support in the middle that you have to take out. I then took the screw out of the old blade that goes through the wiper. I then bought a little longer screw with a lock nut and put the old piece inside the new blade. This worked great. Sea ray wanted $40 dollars each blade and I needed three. The whole job cost me $25 bucks and took 15 minutes.Hope I explained it good. Rich
Cheers! Looks like that's the route I'm going down.
I like a bit of DIY but this whole thing is just silly.
I have thoses wipers on my Trojan F32 and ended up getting them at NAPA. They are used on busses or RV's.
