Old Vinyl Removal
Any ideas on removing the shadow left behind after at name has been on a boat for 10+ years?
The "shadow" is unweathered gel coat (the vinyl protected it)
not much you can except compound the whole transom, might blend in a bit more.
or just let it fade on it's own. I've never found even very aggressive compound useful here. If it is very obvious, the wet sanding is your best bet.
Originally posted by rblochli
or wet sand with 1500-2000+ grit
I don't know much about this but I would be afraid to try this may, very well be the right answer but I would try something less aggressive first then consider other options. Mine was hardly noticeable after a good compounding and with a little time you would be hard pressed to find it.
Thanks everyone. An acid wash and compounding have already been done. Wet sanding may not be a bad idea. We will be covering it with a new name anyway so I don't know if it really is much of an issue. Just part of my anal retentiveness I guess.
You probably wont see it when new letters are in place.
