OMC 800 no go !
timstiles
Cruising across the lake this weekend when without warning the engine RPM's shot up and the boat stopped moving. It won't go forward or reverse and the prop isn't turning. I know it is not the prop. There are no sounds from the outdrive when its put in gear which I hope is good, ie. no crunching or grinding etc.... There is no visible damage to the prop and no other indication that I hit anything. Cable action in both directions feels normal.
What parts on a OMC8000 350V8 1985 could cause this type of problem?
Thanks for your help!
I'm not all that familiar with the model number designations for omc but one quick easy question. Do you know if this is an electric shift omc?
it does sound like a spun prop but the shop i was towed to on the lake said that is not the problem and referred me to another shop that look at the outdrive
The unit in my boat is not the older push button electric shift style.
The electric shift OMC's weren't necessarily push button either. The controls looked just like any other but the drive itself need 12 volts of CONSTANT power to work. You may have an electric shift on there and there are a multitude of things that might be wrong if it is. Could be anything from a broken wire (somewhere) to an exploded lower unit.(internally)
Tanq, all the omc selectric shifts I am aware of all fail the same way when there is a broken wire, burnt coil, bad switch, etc, they fail in forward gear, which is the only direction that does not use 12vdc. 0 volts to both coils is forward, 12vdc to both, if memory is correct, was neutral, and to one coil was reverse, I could have the neutral and reverse parts backwards. What I have seen happen is while it is in neutral, the neutral coil blister on the inside and jam the pin in the neutral position.
Easy way to check this, take the side cover off the controll and take a look, while you have it off and can see in there, look to see what you have, it will either be a series of cables, or a cable and a set of switches. Move the controll from forward to reverse and see what is going on, then have a helper look on the other end of the cable to see if they can see anything move. There is always a chance that this is a cable system, and it came loose....D........
my boat knowledge is fairly limited. I do know that my boat does not have a push button for shiftting, I move the lever forward and back. There is a shift interrupter system on the boat that drops rpms when shifting between fwd and reverse to help save the outdrive internals.
The lower unit was rebuilt 2 years ago and has less than 30 hours on it so hopefully its not that.
D. Andrews....Sounds like you've had some experience with these as to their actual workings etc. Come to think of it.....the first OMC (and LAST) I had was an electric shift and although it failed so many times that I'd go nutso just thinking about it again but now that you mention it....it does seem to have been the "Forward" that always went and I actually once ended up returning to dock in reverse for 16 miles. Boy was THAT ever fun.
oh ya, for what its worth when you spin the prop by hand in gear it spins freely, meaning there is no difference in resistance from reverse, to neutral, or forward
If its 1985 you have a mechanical shift 800 Stringer unit. I have one on my '82 Searay. In fact, I just replace the lower shift cable this winter. Could be a lower shift cable, but I would think it would have stayed in forward since the gears are under cut and once engaged tend to want to stay that way. Bob has a good point about the coupler, although on the 800 it is a steel splined unit that the driveshaft fits into. The splines could be stripped. If this were the case, the engine would overheat since the water pump in the OD would not be turning. What condition are the ball gears? They couple the drive shaft to the upper unit and if totally gone could prevent the verticle drive from turning. Again there would be a heating issue. I'm still thinking a shift cable. Have a shop familiar with OMC look at it, let us know what they say. The Bombardier website has exploded diagrams of the outdrive units that you can download, it helps with the logic tree to diagnose trouble.
Tanq, yea you could say I do have a little. I once had my boat, just off the trailer, unhooked, doing a run up in neutral, fail right then. It slammed in forward, and came to rest in the back of my truck, thats in the bed of the truck.
If you can sping the prop by hand and it spins freely, its either in neutral, or you got trouble. Do you feel any resistance at all? If not, and you have checked the cable ends and seen them move, time for a trip tot he shop........D.......
I guess this is a good time to get my feet wet here.
If you have the omc cobra outdrive, your looking at a lower shift cable problem. I have dealt with this on a few of them. drop your outdrive, you'll need to anyway & set it some where you can shift the outdrive by hand & still turn the prop. if you can get both forward & reverse the outdrive is ok, if not or you have crunchy noises the lower unit has blown due to a bad lower shift cable.
The new cable should come with a new idle down switch, the switch is to drop torque output allowing the unit to come back out of gear & will have no affect on engagement.
This cable needs to be adjusted as a regular maintenance item otherwise a perfectly solid outdrive can eat itself.
I don't have the adjustment procedure for this outdrive handy but it should be easy enough to find on line.
Another vote for getting it checked out NOW. With any degree of luck it'll be an adjustment or cable.
"If its 1985 you have a mechanical shift 800 Stringer unit. I have one on my '82 Searay."
I'm probably wrong but if I remember right the "Stringer" Drives were the Electric Shift and the biggest headache of all.
After about 1977 OMC changed from electric shift to hydromechanical shift until about 1982 when all the 400 and 800 Stinger units were changed to full mechanical shift. If this man has a 1985 OMC 800 it is most surely a mechanical shift outdrive, unless somebody swapped in an older unit. As to why it doesn't work, I've already stated my opinions and I think a shop needs to be consulted for a tear down. Even if its only a lower shift cable, the OD has to come off the boat and the upper and lower units need to be separated. Its a big job but can be done if you are mechanically able.
I'm mechanically able to take things apart. It's putting things back together that cause me problems sometimes! The boat got to the shop yesterday and is awaiting $150 worth of teardown/inspection to see what broke. Shop thinks its the 'waterpump shaft".
that would do it, same thing as having the drive shaft break or the coupler fail or ball gears strip...end result no power transmitted from the engine to the prop. Good news is those shafts are not too expensive and are an easy fix.. It would be a good idea to have them replace the waterpump while the unit is torn down, since the pump is burried in the bottom of the upper unit.
I found a deal on a used boat, will this outdrive or the parts work in my 85 OMC 800? I may got pick it up!
1983 16ft. Beachcraft walk through ,,open bow . 3.8 lit. engine with
omc outdrive
Not enough information and to be quite honest it probably isn't worth the trouble. Just wait till you try to get rid of the rest of the boat if and when you strip it of all the stuff you THINK you may want/need. Getting rid of a Boat isn't all that easy and can get quite expensive.
