OMC cobra 2.3 overheating
jad
I have a 1989 bayliner with the 2.3 tko ford and the cobra outdrive. I burned up two water pumps in one day. the engine is not getting any water. I put the new pumps on with new housings and all. droped the boat in the water and in about five minutes the boat is over heating and the impeller is burned up. I also installed a brand new thermastat. I even took the thermostat out but it didnt matter because there was no water in the engine. I disconnected the inlet line from the outdrive and ran water through it and it came right out at the pump so the line from the water pump to the engine is not blocked. Do you think I may have installed the pump incorrectly?
I am fighting the same problem my self. It is not the sea water pump nor is it the hose to the engine. I have remove manifolds and head. Found impeller pieces blocking cooling passages in the head. cleaned out block. reassembled. still only overheats at idle. runs fine over 700rpm. have melted several sea water pump housings and impellers. "have also inspected engine w/p. npf."no problem found" I did notice that when I had the exhaust manifold off that there was a steel rod in the exhaust where there is a rubber hose connecting exhaust manifold to the exhaust. I there suppost to be somthing else there? like aflapper or somthing? and could this be the cause of both our problems?
Try running the muffs with the pump removed. See how much water comes up the inlet side. Or, better yet, run the hose down the inlet side of the water pump to back flush the inlet screen.
Next, make sure the new impeller is lubricated with WD40, Silicon spray or Dish soap. Make sure you use a full size garden hose for the muffs. I've burned up impellers using a hose coil. For some reason, the hose-coil doesn't push enough volume of water for the muff/outdrive.
I have received water pump impellers that were the wrong size for the OMC housing. They were just a tad too big, which caused a lot
of friction and a melted pump housing.
The steel rod, mention in the above post holds a rubber flap valve. The valve prevents water from running up the exhaust tube into the engine. This can occur in heavy seas, when the engine is off. They're not too expensive or hard to install. Sometimes you'll find flap valves that are partially burned up from overheating. I know Volvo had a problem with this. The partially melted valve would lodge itself down in the exhaust Y, causing back pressure problems.
found my problem. ther is a pickup tube from lower unit to upper unit to the sea water pump. the seals have been melted due to the exhaust getting too hot "not enough water" and I did find the rest of the flapper in the lower unit. so with the muffs on there is plenty of water to cool the engine. but when the boat is in the water the pick up tube is surounded by exhaust and water pressure around the drive. the water pump will pull in exhaust causing overheating. hope this helps.
Check to make sure you have the 'IN' and 'OUT' hoses connected right.
