OMC Cobra Outdrive
cmpcpro
Hey guys, I have a couple more questions for you. I started the boat in the driveway with the fake a lake and the outdrive was all the way up, and at around 1500 rpm in nuetral it made a slight clank noise like it was a loose bolt, but it was hardly noticable. Yet when I put it down a little it goes away completely. Is that normal? Also, seeing as I just got this boat, should I be checking anything on the outdrive? Does it have oil? What about the impeller?
Also, how do I change the oil on the motor? I cant really get a drain pan under it..
Thanks guys, sorry for all the questions just trying to figure this all out.
Chris
