I used Barr on my Pleasure Craft 351. The original eq. and Osco manafolds have 2 bolt holes per cylinder but the Barr came with only one bolt hole per cylinder. Also, when I remove the spark plugs I have to remove the Barr manafold first, I did not have to do that with the OEM manifolds. I have no experience with the Barr on GM engines. I would not use Barr again. Good Luck, Jerry
