OT: Stain Removal help needed
pgilbert
Need some help. How can one remove brown deck wood stain from white vinyl siding? Some dribbled on the siding while doing the deck. Tried magic eraser and various "turpentine" fluids with no luck. Also tried acetone. Anyone have any ideas??
You can paint vinyl siding. Not the best solution but it does work if the staining is bad enough. Replacing the stained pieces as well but that is obvious. Sorry I can't recommend a solution to actually remove the stains.
Vinyl siding is easily removed & replaced with new !
Try MEK. Home Depot should have it. If the does not get it, you have to mechanical, IS sandpaper, or replace it.
HMMMMM, thought this was boating related only. This is what NBR is for.
