Outdrive Bottom Paint Removal
austingm
I am removing 10 years of bottome paint from my boat.
The Hull paint is very thick so most of it literally just chpping off with a small chipping hammer without doing any damage to the gel coat. In spots where it wont chip off I am using the appopriate paint stripper (gelcoat friendly :))
Do I use the same stripper for the outdrive (Alpha 1 Gen 2) or is there some other stripper that is recommended?
Also, after the outdrive is stripped, do I just apply outdrive bottom paint or is ther some type of primer that needs to be applied before?
THanks
Austin
I used to sand it down. Never used the gel, not sure if that will work or not. After that I would repaint it with the mercruiser outdrive paint. I then used the clear anti-foul outdrive paint. I dont know if they have the clear any more since they outlawed the lead...
I have the same engine/outdrive. Had the outdrive painted professionally [total 5 layers of prime and paint]. After 3 yrs, the outdrive looked really bad. To me, it wasn't worth having it done again. Instead I put my boat on a lift out of the water when stored!
It is not the layers, of paint, it is the conversion coat underneath that will dictate the quality of the paint job on aluminum.
