Ray: Engines in or out, it may be the same problems. The upper swivel pin must be driven out from below, the lower swivel pin still must have the cotter pin removed. The bellows still gotta be removed. Same thing, engine or no engine. WGE
raymond smith <rayandjoyce1rb2@gr5tverizon.net> wrote: Wow!!! The more I study this the more I'm convinced to pull the engines to do this project.
Ray
Dr Wayne G Elliott <welliottrb2@gr5tsbcglobal.net> wrote:
And I ain't finished! Todays news follows. With a chisel and a lot of hammering I managed to get the nut on top of the upper swivel pin to turn. It turns freely but now jams into the outdrive housing above it. I then turned my attention to the lower swivel pin. Following the directions I commenced to remove the cotter pin. How they managed to insert a three inch cotter pin into a swivel pin with only one inch of clearance on each side I do not clearly understand. The cotter pin was corroded and refused to budge. I pried, I poked, and I cried. It refused to slide out - corrosion held it tightly. In desperation I drilled a three sixteenth hole in the side of the gimble ring, inserted a small drift and managed to push the pin out. Bravo! Then I took another stouter drift and drove the lower swivel pin out. By this time I was frustrated, exhausted and the temps and humidity were climbing. Tomorrow's event will include: removing the universal joint bellows - the hose clamps are in some incredible position requires a very skinny screw driver or a univeral joint 5/16th socket and tiny fingers to loosen the clamp. Then, having access the the threaded hole on the undersurface to the swivel pin - which may either be a 3/8th or 7/16th - mine is 7/16th - I will retap the threaded hole. The threads are hopefully salvagable, having been immersed in several years of salt water. I will then either insert a slide hammer or a 7/16 bolt with a flat steel slat and try to bang the upper swivel pin downward with enough force to remove it. It looks rather corroded at this point and I am not too encouraged..
Why Mercruiser inflicted this mechanical, unfixable nightmare on the consumer is beyond me. An accredited mechanic would face the same problems. At any of a dozen points these problems could be easily avoidable. When (and if) I ever get this bunch of crap reassembled it will be with copious amount of Never-Seize and stainless bolts, nuts and easily approachable access holes.
I hope I have described this adequately. You may paste this into the web site. WGE
Thanks for the info. Best of luck with the rest of the job..
Ray
Ray: I am in the midst of the repair as I write. I opened up the back of the gimble ring without too much problem. Getting the holes exactly in the center of each of the four tapped holes to mount the cover plate has been a bit of a problem. They must be exactly in the center of the cover plate holes to fit correctly. Rather than use the paper "jig" to find the hole centers it would be better to use the plate itself to align the holes.
When I got access to the swivel pin I had to remove firstly the bolt that holds the steering arm to the swivel pin. It took copious amounts of break-free fluid and a breaker bar to turn a socket. The nut happened to be an 11/16th and the bolt head was a 5/8th. Go figure. Anyway, after removing the nut it took a lot of turning with the socket to back out the bolt.
When I replace this nut and bolt be assured that they will be stainless with a self retaining nut! I am now trying to remove the nut at the end of the swivel pin. It is totally rusted to the pin and I am letting it soak over the weekend. My machinist guru says to rap it smartly with a drift - it may enlarge the nut somewhat and allow it to turn. Failing that I will chisel off the nut. Again, any thing that goes back on the stainless pin will be a stainless nut with Lock-tite.
I haven't even approached the lower pin but it looks like a piece of cake.
Is this any help? Wayne Elliott
RayandJoyce1rb2@gr5tverizon.net wrote:
Hello dollelliott
You received the following message from: Riverfever30 (RayandJoyce1rb2@gr5tverizon.net)
At:
http://www.boatered.com/forum/
How did you make out with your swivel pin replacement? I have the same problem and have aplhas. Any help will be appreciated.
Ray
