Outside winter storage Michigan
vv1212w
Have been inside heated winter storage the last 9 years but going outside for the 1st time in shrink wrap this winter. Reason is that I get another three weeks in the water spring and the same in the fall due to marina restrictions for inside/heated. Question. Have a 30' Sea Ray Express in MI. Lake st Clair. Not sure what to do for the cabin area relative to moisture/mold/freshness in the spring. Will appreciate suggestions on protecting the cabin/cockpit are for the winter storage. Thanks...
Damprid or any similar type moisture absorbant. I do two or three in the cabin, and one up top.
Just make sure she's good and dry when they wrap it and you'll be fine.
I use kitty litter and damprid mixed together in 6 showbox sized containers spread through out the the boat. I also keep most of my hatches and the cabin door open so it can breath and I use white shrink but I'm not sure that matters.
Good luck
Niles
Air flow and damp rid. If you are shrink wrapping or tarping, leave the ends open for air flow. Boats are made to get wet on the outside, leave some hatches open and don't wrap it up too tight. Don't forget about a couple of mouse traps for the mice.
Go to Google - search "calcium chloride". Read all the ways it is used to control dampness. When done Google search "McMaster-Carr". When there search "calcium chloride" and place your order. If the small order is too much product share with a friend or ------. Good luck!
PS McMaster-Carr is among my very favorite companies, alone with L L Bean.
