Considerations:
Before you get a three-way RV unit check the amp draw or watt on the beast. As they're designed to run on propane, the electric modes use heating elements rather than a compressor. In my experience, they're power hogs (unless of course you run them on propane). If your boat is set up so you can safely use propane, then go for it.
Re compressor size, while a 2 amp compressor is great for advertising, it MIGHT actually draw more power over time than a 5a unit that runs less.
Glueing extra insulation on the sides and top of the fridge will usually help, too.
It really doesn't take much of an inverter to run a fridge. I originally used an 800w dedicated inverter to run my 9 cu ft fridge and it worked just fine. I've since gone to a larger inverter, but that was simply so I could run more stuff...
