Ozone Air Purifier
mintregila
Anyone ever use one of these ozone units to eliminate smells and prevent mold/mildew?
The Admiral has a very sensitive nose and my boat always has some water in the bilge. Shaft logs are properly packed and adjusted so they drip when running and almost not at all when at rest. All scuppers and deck hatches are plumbed to drain overboard so there is little rainwater collecting there. Problem is that bilge pumps don't pump completely dry and therefore you have salt water sitting in a hot boat all week.
Lately, I've been running some fresh water into the bilge when I get back to the dock to "flush" it out and I have also been leaving my AC units on set at a higher temperature rather than on the humidity setting. This seems to help tremendously.
Just wondering if anyone has used any of these units with success.
For me, I would find them problematic. The reason is that ozone is a) corrosive and b) a respiratory irritant. My boat's wiring and my lungs are both sufficiently corroded that I do not need to accelerate the process. IMO.
I would suggest even more diligence on stopping the problem at the source, including adding ( if needed ) more bilge ventilation.
I had a friend who bought a Mainship 350 that was a liveaboard on the East Coast. The original owners also had a dog on it.
He got a good deal on it, but it smelled to high heaven. He removed the carpet and replaced with wood but it still smelled.
He borrowed an ozone generator and it got rid of the doggy smells in the cabin. It took a couple of weeks.
But I am not sure how it will work in the engine room.
On another subject, I installed one of those solar powered vents for my
engine room. It won't get rid of all the soaked in smells from the past
years, but it keeps clean air passing thru it.
I was one who invested in the Alpine air purifiers several years ago. I bought a commercial one for de-odorizing cars and it worked well, but the source point must be eliminated or minimized to get true relief in the worst cases, like dog odors, etc. Bottom line, they do work, but you must read the instructions carefully. It's best not to be in the area when it's on. I ran them in many cars, sometimes directly on the dashboard for 24-36 hours, and never saw the degrading of plastic. It would take a lot of time to do that, IMO. Also, ozone breaks down rapidly, so you could occupy the boat/area in a short time, with ventilation. (10-30 min.)
Most people who had problems with them didn't bother to read how you should adjust them properly.
Ozone works for odor removal but not as an air purifier.
Buzz
I've used one on boats for many years and not had any problem.
I agree with Buzz that they work to eliminate current odors from dogs/smokers/or that general musty smell when a boat is not ventilated, but they do not cure anything.
The ozone machine should be used for a while when the boat is vacated, but not too long...an hour or so suffices. When it smells like a swimming pool then it is time to switch off. The boat should then be ventilated for 15-20 mins before normal activity.
Just my opinion...nothing expert.
I use one in my bildge area.. Mine smelled bad.. Mildew etc.. This is under the forward birth.. It took a couple weeks to completely resolve the smell. If I shut down the unit over the weekend the smell is just starting to return when I leave ( and turn it back on again.. I too tried everything to relieve a smellyt situation.. In the end the best I could do was to mask it.. It works. I run it on a very low setting.. First thing I do is open two windows and run up the AC.. I cant smell the ozone when I first get on the boat.. I cant smell the nasty stuff anymore either..I'm going to get another one to run in the cabin too.
Read the government reports available on the use of ozone. If its strong enough to work, then it is a serious health hazard. I believe the facts vs. the marketing hype put Sharper Image out of business.
Thanks for the input. I think I will take a pass on it and keep doing what I do which seems to work.
ozone is kinda like a double edged sword. it is o3 a very unstable compound that will oxidize just about anything it comes in contact with and revert back to its natural state of o2. thats why its very good at knocking down airborne pollutants, it oxidizes them. i've had a boat with gas carbs that would stink to heaven when the gasoline would evaporate from the carbs on a hot engine after it was shut down. bildge buster is a coast gaurd approved ozone generator and it worked magic to get rid of that smell. i highly reccomend it. but you should be wary of high concentrations of ozone as it is poisonous if concentrated. use it with caution and you will get results second to none. the only way to get rid of smells is to either remove the air with the smell in it, remove the source of the smell or oxidize and or filter the airborne pollutants. any other kind of air freshener will only mask the smell.
Ozone generators and guns are safe, it's the operator you have to watch!
El Sea
IIRC it accelerates the aging of rubber in hoses etc
