Tanq, visual distress signals are required on most waters. I'm assuming that the location where Pascal was boarded was 'protected' waters. 33 CFR 175, which requires visual distress signals (usually flares, but there are non-pyrotechnic devices that meet the requirements as well), doesn't apply in such waters. Essentially, inside waters where the narrowest point between shores is less than 2nm, but I'll cut and paste the section below. The Applicability section of 33 CFR 175 lists "Coastal Waters", which are further defined in the Definitions section as follows:
§ 175.105 Definitions.
(a) Visual distress signal means a device that is approved by the Commandant under 46 CFR Part 160 or certified by the manufacturer under 46 CFR Parts 160 and 161.
(b) Coastal waters means:
(1) The U.S. waters of the Great Lakes (Lake Erie, Huron, Michigan, Ontario, and Superior);
(2) The territorial seas of the United States; and
(3) Those waters directly connected to the Great Lakes and territorial seas (i.e., bays, sounds, harbors, rivers, inlets, etc.) where any entrance exceeds 2 nautical miles between opposite shorelines to the first point where the largest distance between shorelines narrows to 2 miles, as shown on the current edition of the appropriate National Ocean Service chart used for navigation. Shorelines of islands or points of land present within a waterway are considered when determining the distance between opposite shorelines.
So, it's not 'Inland Waters' as we usually think of it - in reference to the '72 COLREGS demarc between Inland and International Nav Rules, but 'protected' waters as defined - or more accurately, NOT defined - by 33 CFR 175.
