Pascal, Sand-bar Hopper directions?
jtybt15
Got the major components collected. 10' dink(4' wide) with cathedral type hull so it has fairly vertical gunnels. Hobie-cat pontoons(16 1/2') I just got last night. Looks like one side is fairly vertical so I expect to mate these surfaces. HOW???:D
Both pontoon and dink have an outward curving lip. Did you cut off?
I don't expect to start working on it yet...still collecting parts.
Got pix of construction?[:I]
charlie
i didn't use an old dink in the middle. I cut the hulls at 14' and glassed a plywood transom to link them. At the bow, I glassed in a 2' long "deck" on top of the hulls. Once that was done I flipped it over and added a plywood bottom. I used the flat side of the hobie hulls outside.
If you're going to use a dink in the middle, you need to find way to mechanically secure the hulls in addition to bonding and glassing the outside. Screws won't work obviously, maybe toggle bolts?
"Hah! You call this a Storm?" Forrest Gump's old Lt. talking to the head weatherman.
Yeah on the fastening. You need as much of a 'footprint' as you can get at each stress point.
Boy do I wish I could use one of thost 3-D Drawing programs. That would be so handy right here.
Yeah, the pontoons are somewhat triangular 'tubes' with no access to the inner surface.
What are your overall dimensions?
C'mon thud, need some ideas.
the first one, using hobie 16 hulls, is 14' ( I cut the last 2', right behind the aft frame. The second one, built from scratch is 13' Both at 5' beam (widest I could fit on my boat...)
