Pirate I need your help
dalehollow
this may start a riot, but was given your name
looking for an AC unit for a houseboat, btu's not an issue. I only have a 5kw generator Westerbeke, and the output is approx. 36 amps at 11o voltage, the unit has approx 18 amps at 220 volts. Hate to go to a rv style roof unit or a convential window unit. Your suggestion on these facts alon lol thanks ... earlier post most of the suggestions fail to consider the start up amperage prefer a duct type system that i can contol what small areas the air goes to
have you see the split kind that go through a house wall with only a small tube?
yes thanks someone mentioned them earlier waitting for a reply from the company sounds like it might work
I don't know what size your boat is, but why don't you consider a marine air unit? An 18000 BTU unit will only draw 15amps. The new ones are small enough to place almost anywhere- in a settee, under a bed, in a closet. They're very efficient, and quiet. You could use 2 smaller ones if necessary and create 2 zones. My .02 cents.
Unless everyone can't read he doesn't want our opinions only Pirates whoever the he** that is!
Dale why don't you start a 3rd post/thread about central air conditioning?
Pirate doesn't post on this board, but he's often on both of the Houseboat-oriented Forums. Check with Old Houseboater, he knows Pirate.
thanks vic, sure wasnt trying to get such a mess stired up i did a poor job of explaining what i was up against, I have got to the right site I beleive
