Plastic Innovations Dingy Davits
Leeway
Was looking to buy Weaver Davits for my 8 1/2' dingy and I came across this davit system by Plastic Innovations. Seems like it could work for my particular situation, however the hoops are made of plastic and wasn't sure about the longevity of the system. They are quite a bit cheaper than Weaver Davits, however I know the old saying "you get what you pay for".
Anyone have any experience with the Plastic Innovations davits? Any thoughts, good or bad.
Thanks, Ken
I was given a used set of C-lift brackets in 2003. I don't know how old they were when I got them. I've been using them ever since. One of the base pieces did break at the end of last season and rather than just replace that piece I got a full new set. Also, I drilled a hole through the tip of the hinge pins and put a clip through it to secure the pin in place as early on I had the pins work there way out while underway. And I teathered the hinge pin and clip to the C piece so I wouldn't lose them in the water. With that modification they have worked very well for me.
They come with a lifetime warranty, one of my hoops broke and they replaced it with no hassles. I used it for many years on my previous boat and loved them.
Used them for 3 years on my old boat and had the exact same observations and experiences as PJS. They are cheaper than Weaver snap davits but at 1/5th the price they are well worth it and worked very well for me.
However, I went to buy them for the new boat and discovered that it seems they are no longer in production. Let us know if you are actually able to buy them.
Thanks for the replies. I'll check to see if they are still available. Defender Industries in Waterford CT still has them in their catalog.
Ken
Ken
But you won't find them on their website and if you call they'll tell you that they are on indefinite back-order. At least that's what happened to me.
I guess they must be back in production. I ordered a set and they arrived yesterday. Seem like they will do the trick.
Ken
Ken
Interesting, good to know. Good luck with them, I was happy with mine.
