Play in wheel steering
eldon1562
My 40 ft Heritage has a full 6 turns of the wheel at both the upper & lower helm.
As I am in a very tight moorage & do not have rudder angle indicators I have trouble when pulling away from the dock in getting control of the heading.
Anybody familiar with tightening up steering?
I have a 27 Cascade which has only one turn in each direction at the wheel. Sweet to manouver!
thanks,
Loose at the Wheel
It does not sound to me like "play" in the helm but the designed "turns, lock to lock" are excessive, from your perspective.
Assuming that this is nothing new, it is a designed in thing.
Please, further describe:
a) make and/or type of steering ( push-pull, hydraulic, cable )
b) Did I understand you correctly? Is the issue simply too many turns or is this a newly developed issue?
34' silverton convertible - has 5 full turns. Hynuatic steering.
The boat most likely has Hynautic steering. Most are like Britanic's 5 to 5 1/2 turns lock to lock. Unfortunately with hyraulic steering, because of "creep" you cannot lable a king spoke (center position). (the Davis position indicators don't work for the same reason) If you don't have a rudder position indicator, then go lock to lock and come back 3 turns (or 2 1/2).
Sitex makes a rudder position indicator (about 3 1/2" dial") for about $300. If you have an auto pilot, you can make one fairly easily--either using the information from the pilot, or the rudder feedback unit and a dial. (basically is a potemeter and you read resistance on the dial)
Thanks for the help ... I've got it figured out with the help of a couple of the wharf rats here & info you've suggested.
Eldon
