I am trying to determine if I need to replace some suspect plumbing on the waste system from the previous owner.
My question surrounds the water intake seacock to the head itself. It appears (although not confirmed yet) as though Sealand Odorsafe hose or Shields equivalent is plumbed directly from the below water line seacock directly to the head. I am unsure if this is acceptable because the hose may not be rated for direct connection to a seacock.
What is the best way to address this? Purchase the black reinforced hose that is rated for direct seacock connection and then form a loop above the water line. Finally use a union to connect to the current hose to the head?
Thanks again.
Doug
Thanks again.
Doug
