Poor TV reception - advice?
marykhubby
Poor TV reception issues here...
Just installed a new HD set hooked up to an omnidirectional marine antenna. Antenna performed well on my prior HD set on the boat.
Here's what is strange. Reception is knockdown PERFECT when I only insert the small diameter inside wire into the coax cable connection. As soon as I make contact with the outer nut on the mating coax connector, the picture gets worse (snowy for analog, or intermittent on HD channels).
I have swapped cables, jumped the splitter, and even connected the antenna directly to a short run cable on the TV. No luck.
Any experts with some suggestions to remedy, or troubleshooting advice?
Appreciate the input.
Don
That's usually some type of Grounding or Shorting issue.
Have you tried connecting a cheap pair of rabbit ears to the TV to see how it works? That will tell your if it's your Antenna setup or the TV. I would isolate that first. Could be a short in the connector on the TV.
If the antenna has a preamp, that could be the cause as well. How old is your omni antenna? The plastic on those things get brittle, and when moisture gets in there, they go downhill fast.
For now, if you can't resolve it, just cut the connecter, strip back the shielding, and use only the copper wire since it was giving you a good picture.
Airbus
It has a preamp, but I bypassed that as well during the troubleshooting - it's "clean".
The antenna was new last year and has not been outside (until last month). I am thinking TV connector so your suggestion on the rabbit ears is next.
OR
If I hook it up to live cable, if the TV connector is bad, will it show up? I could bring the set home and test it this way. What do you think?
Brought it home today. Works great hooked up to live cable. I'll go for the rabbit ears next...
Make sure you run a setup channel scan when you hook it up. It will basically go thru and lock in the channels. Learned that one the hard way. Good luck.
