prop paint causing vibration?
Britanic
This weekend was my 4th time out with my new props (just tuned) I ussualy do not paint them, however this year, at the advise of my yard owner,I sprayed them with some $45 a can spray paint.
Performance has been great, until...
I was in a back cove looking to set the hook, moving at about 5-6 kts (900-1100 rpm) when my bow rubed the bottom. I immediatly pulled throttels to idle and saw a little mud kicking up.
Reversed out - boat came right out and was back in the channel in no time. Found a new spot and spend several hours there before heading back.
Now at cruise speed (19kts at 3000rpm) I have a slight vibration. You can feel it in the seat and the bracket mounted displays shake a little. More throttle and speed magnify the vibration. Performance does not seem to be affected.
Definetly the port side. I went out the next day and went for a swim. One blade on port side(3 blade 18x20) has no paint on the back side (facing bow). Possibly I missed this blade during my prep and the light grounding took it off.
THE QUESTION - do you feel that this condition would casue the vibration I described.
Boat is 1988 Silverton 34 convertible with 350/270 crusaders. I first plan to scrape the rest of the paint off. If that doesnt cure I will haul and retune prop
Could have some damage to the prop that you can't appreciate in the water.
My opinion: I don't think the paint or lack of it is causing the vibration. If it was not there prior to your light grounding, logic says the grounding has upset the gods. Other possibilities-bent strut throwing off the alignment or bent prop shaft. Put the port engine in gear at idle and look at the shaft in the engine room to see if there is any wobble occuring. If no wobble, more than likely the prop is the culprit.
