Originally posted by TJM
David: Teflon tape or any other product is big NO NO. The props stay on because of the self locking machine taper (and the key) that is precision machined and concentric to the mating prop. Anything outside of that shaft geometry will cause problems with the alignment. For example, a raised burr on the shaft can cause vibration, while a negative defect: divot or pocket like, is not as much of an issue.
The torch heat on the prop works because of the thermal expansion of the Bronze or Nibral. The heat expands the inside diameter, and yes, too much can be a problem. Timing is a variable also. If you wait too long the heat transfers into the shaft, expanding that as well.
