Prop question from a newby.
mls
I'm new to this forum but enjoy reading the posts. I recently bought (to restore) a 1983 21' Sea Ray runabout with a 260hp merccruiser in it. The motor is strong but someone had stolen the prop and I need to get another. What size and pitch would you experts on here recommend for just pleasure use and pulling the grandkids on skis. Of course I am going to get a stainless. Thanks a lot.
If you go to the Sea Ray site, there may be an archived record of the boat you own and the original prop.
IMHO, I would not limit the search to stainless. A lot depends on where you boat and what is under the water's surface. If you have a lot of logs of submerged stumps, stainless is very unforgiving. A trashed prop is the least of your worries should you strike something. A complete lower unit replacement is not uncommon.
I trashed an aluminum prop on my Regal. I replaced it with a Piranha composite. About the same as aluminum and 1/3 the cost of stainless, smoother than aluminum and very forgiving. Plus they allow you to dial in your perfect prop as the changes only require changing blades as opposed to the entire prop.
My 2 cents.
