Prop shaft lube?
jstokes
Through a feat of superhuman patience, a wheel puller and some busted knuckles, I have just managed to get the 16X10 RH prop off my little Albin trawler. The last time this prop was off was in October, 2006.
Questions: Is it advisable to use something like NevrSieze on the shaft when I re-install, or is there some electrolytical or other reason not to do so? Thanks. John in Augusta
Dunno. Some will say that tight a fit is the way it's supposed to be. I've tried never-seize and ordinary grease. There may be some issues with copper-based never-seize but probably NOT with grease. I've tried both and not encountered any unusual issues, and it's nice being able to pull the prop without hauling the boat.
On a high-speed boat it may be a problem, but for a lower-speed trawler or a houseboat like mine I kinda doubt it.
I too think it supposed to be dry, the key alone is not designed to take the torque. Look up Morse taper, for technical details of this magic design that uses friction to transmit torque between two parts.
A common error when reinstalling is having the key too far into the slot and thus keeping the prop from properly seating.
even low speed boat transmit considerable torque to the prop especially when shifting.
No lube is best. If it wants to spin freely because of the grease, you will break the key and have to be towed in. Clean the prop taper and make sure the shaft is smooth and clean. Put it on there first without the key using just spit for lube. Turn it by hand while pushing in several times. Remove it and clean the shaft and prop taper again. Then put it on for real.
While dry is recommended. And lapping the prop to the tapper is a good thing to, in the real world, I like a little anti-gall on the props.
You are the pro driving stuff much larger than the majority of us here.
Have you ever had any issues? I see heat and cold applied time after time to remove a prop coupled with some sailor slang. It would seem in this day and age, someone would have invented a better mouse trap. They did for OB's and I/O's
weird stuff needs to be considered. Who would ever think that a prop sitting in the sun might expand and be difficult to remove later because it was hot when installed?
[/quote]
[/quote]
Yes I've seen lots of issues.
The ideal way is to get the shaft and prop/s mating surfaces perfectly machined to each other. Then have them lapped together and dry fit.
That rarely seems to happen. So that is why I like to use at least a bit of anti-gall.
Pull props no matter what there sizes often involves heat and colorful language. And in fact can involve explosives. (No I'm not joking.)
The best way to avoid most of that seems to be to take your props off yearly and check and clean the mating surfaces, key way and key.
On inboard props it's also a time saver to pre-drill the hub and add threaded holes to except the Prop Smith prop puller.
http://www.propsmith.com/
I pulled my props off a salt water boat after 5 years my ownership, lord knows how many by the previous owner, with no problems using a safeway prop puller and some big adjustable wrenches from Harbor Freight.
I used to think that never-seize was the answer. However, the more you learn about a morse taper, the more you realize that a proper taper won't care and an improper one it might be a bad idea. Dry really probably is the preferred method. I still use a little something, but that's not really the answer.
The trick to getting a prop to let go is technique and the right tools. That means a good heavy puller, perfectly aligned, pulling hard was can be. Then you simply need a shockwave. A good morse taper will usually not let go with puller force alone. That's normal and what most people define as "a problem". It's not a problem, you just have not gotten to the end of the removal steps.
The short of it is that the most common way to setting up a shockwave is to simply hit the end of the shaft with a heavy steel mallet. No, you don't want to use a piece of wood as you WANT that blow to ring. This is not about force, per se. Done correctly and you will find that very few of those props you formerly could not get off will continue to give you problems. They simply come right off. Done incorrectly and you can bend a shaft, ruin a prop and so on. Its really quite simple, but maybe you want to get someone to show you how it works. It's hard to describe what an adequate sized puller looks like, or the true amount of force to put on it, the size of the mallet and the force of the blow (dead straight on, not sideways).
I found that once I got the puller set up right and put a strain on it, the prop popped right off with a satisfying "clang." No hammer needed. The only down-side was that I had to drop the rudder to get the puller on, a job I was trying to avoid.
That PropSmith looks like a useful tool, but they apparenly don't make one in my size-- 1"SAE.
Thanks, guys for a great discussion and a lot of very useful information.
