Prop Slip Dash Gauge
Sandy
Since inevitably discussions of prop slip pop up here, I thought it might interest others that Livorsi Marine has introduced a single round LCD gauge that displays constantly calculated prop slip for 2 engines' props at once, taking into account prop pitch, gear ratio and GPS speed. The same 4 5/8" dia. cut-out/ 5" gauge also displays digital single or dual tach info, GPS heading, GPS speed and max speed since last reset. It even has a removable recording memory card so one could upload performance data to Livorsi's site so it can be displayed as a printable graph and the card can also be used to update gauge software as available.
It's called the "DataTach Prop Slip Multi-Gauge" . Pretty interesting but of course it's not cheap . I'd expect the target group to be go-fasters, though I imagine most anyone might be interested in dynamic readout of %slip, especially when fine-tuning prop selection.
I just saw this in the new gear section of Soundings and checked out the website & thought I'd pass this on. That ad said $849 retail but I think the website indicated a "boat unit +" for the kit, could be wrong.
This is way beyond anything I need to know! As long as I get up on plane as quickly as normal and can run 27 kph at 3800 rmp, I'm happy! If I'm off a bit, adjusting my trim taps usually gets everything back into norm.
i wonder if that will work with surface drives? i often question if we should run the drives deeper when we run above 120 as the hull lifts onto the lowest strake i can feel it get very twitchy or nervous as its pretty narrow prop shafts are 36 inches apart, this might be a great driving tool if it works and is tough enough to take the pounding
