Propane grill on bow rail
king5899
In another post someone seemed negative about using a propane grill (Magma kettle propane version). Are these safe to use when anchored and mounted on the rail in the bow area?
A concern on the bow rail would be access and safety of the person's position on the foredeck, but it is certainly safer than mounting the grill over the fuel tank vent!
I have a charcoal Magma which mounts at the very port stern so it is not over the swim platform or the port gunnel. I remove that section of canvas and the wind blows the heat and any sparks toward the water and away from the boat. When not in use, I store it in canvas bag down below. The fuel vent is on the starboard side below the rubrail.
We use electric grills only.
Granted that it may not be as tasty as propane or charcoal cooking, but on a boat or dock we consider it to be a whole lot safer.
I'm not allowed to use mine at the dock. I only BBQ when I'm anchored out. We have a community BBQ [propane] at the dock.
There is absolutely no problem useing your gas grill mounted on your bow rail. this is the way it is mounted on our boat. of course common sense is always required when playing with fire.
Have a great weekend.
Nothing wrong with having the grill on the bow, we have our mounted off the stern as it's easier to use we usually eat in the cockpit and we are liveaboards so use it several times a week.
We use propane but usually also use wood chips to get the charcoal taste without the hassle.
You want to have it where you can keep an eye on it. You're cooking after all. Mine leaks meat drippings, so I wish for it to be over the side a bit, so I don't have to clean up. Some grills are affected by the wind. If you have a cabin, you might want to put it to the lea of the cabin.
If you anchor off the bow and have your grill mounted on the bow the wind will blow the smoke through your cabin.
I'd avoid mounting it on the bow, mainly for safety reasons. If it's on the stern you're likely to be operating it while standing firmly on two feet. If in the event a stray wake shakes things up you're less likely to have problems. The same isn't true when trying to negotiate the curved bow deck. Then there's issues with dropping or slipping while carrying various cutlery. So while the grill will "work" in that location, getting back and forth TO it may be unsafe.
I believe all Magma grills are designed so that the lid can be set on the kettle in a position which protects the grill from the wind. It has an oversized washer under the knob screw for this purpose. Works very well.
