Propeller and Shaft Coating
gcolton
Well-known member
Sunday I was watching Ship Shap TV. During the program a product that is used to coat the prop shafts and props was shown and talked about. They said this product made it much easier to remove growth and kept both prop and shaft in better condition.
I thought they said this product was either made by Pro Speed or was called pro speed. I cannot seem to get anywhere googling these words. Did anybody see this show and do better at getting the name?
G
Oh, that one little ole letter that gets left out makes a big difference.
Thanks.
George
Propspeed is simply a cleaner for which the active agent is phosphoric acid--any auto parts store will have rust removers--check their labels until you find the one that contains the acid. It will perform just as well at a significantly lower. price.
I use muratic (hydrochloric) acid to clean my nibral props.
There is a Pettit product called Prop-Koat. It is a 2 part application with a primer and top coating for underwater metals. I met someone this summer who has used it and swears by it. Apparently it produces a very slippery surface so that when you are running, growth slides/falls off.
Prop speed is not a cleaner it is a coating,two part expov product. Ideal for saltwater use,especially on high rpm vessels. It works, We are getting ready to haul for our bottom job. It has been two years. Propspeed is still working,although not quiet as well.
Once you apply the product,you simply wipe your shafts during your cleaning. Here in Florida we need to clean the bottom of the boat between every six weeks or every 10 weeks,depending on season. It works.
Critical is the applicatiom, follow directions exzctly or it won't perform as well. As said goole propspeed and call the will ship it direct to you.It is expensive,but well worth it,IMHO.
I talked to a PropSpeed rep at the Annapolis boat show. Looks like a great product, although very expensive. I am looking to try it next season to limit the barnacle fouling on my props and shafts.
I also talked to a Pettit rep at the Annapolis boat show and he had no real information on the product since it was very new.
You can also use "Interlux 2000". Light blast of prop, shaft, strut. Coat with the "Interlux 2000", while the epoxy is still tacky coat with your normal anti-foul coating. Interlux 2000 is not cheap but will last a full year in salt water use.
Keith you are correct on all counts. One difference with Prop speed,it is lighter,less drag on props and shafts and thus more economical. This almost two full years,the boat has not been out once, shafts,props still have no barnicles or groth attached to them. Last couple of cleanings we have noticed some slime,wipes off with a very light brush.
I will replace the propspeed again. Very pleased with it.
Oops I got the data above from the MSDS sheet --unfortunately, downloaded the cleaner Propprep not the product.
My experience with the product was not so good. Did not hold up all that well, I am having better results with a good polish finnish. I have the diver clean the bottem every month as the boat is in Miami.
Cor
Cor
I understand the stuff is about $700+- plus labor - that pays for alot of diver cleaning
It is expensive, cost me $400.00 for a 28' twin engine boat. The labor was done by me,it is not hard,directions are clear and very easy to follow. Key is you need two people,second part goes on right after first part,no waiting time. If this part of the process is not done exactly as described,it will not be as effective.
BTW you can get it at West Marine, but you will pay more then if you buy direct. I believe it is worth the money in performance and thus fuel saveing.
local reports are that sandy water and careless divers kill most applications.
Bruce,
Correct. The factory rep told me two things will screw this up. First not following directions closely and completely. Especially the part about using two people, one coat directly behind the other. Most marinas/boatyards send one person. Second was carless divers who use scrapers to clean it when only a soft brush is needed. BTW during those months when the boat is used a lot the divers have found the shafts and props etc clean or only in need of a wipe down with their hand
