Proper fueling procedures
  • Thread starter Thread starter blouderback
  • Start date Start date
B
blouderback
Guest
rduhon's post about his experience at the fuel dock recently reminded me about the questions I had when fueling at the dock. Being a trailer boater, I don't often fuel up at the dock, however, every once in a while, it is a must.
My prcedures are as follows, please correct me or add to the procedures as you see necessary:
1. Slowly motor up to the dock, port side to (as this is side where the fuel fill is).
2. Tie up and shut down the engine. Accept assistance from the dock hands, if offered.
3. Disembark everyone but me from the boat.
4. Open the engine cover, and all other hatches (it's a bowrider, so I don't have any others).
5. Make sure all electronics are off, especially those in the engine compartment (such as the blower). Question: What about the bilge pump?
6. Take the pump handle from the attendant and begin filling. Do not let the attendant do it!
7. Stop filling when I start to hear gurgling. DO NOT ATTEMPT TO TOP OFF, NOT EVEN A TINY BIT!
8. Replace gas cap.
9. Sniff around the engine compartment, and look around for any spills.
10. Turn on blower for 4-5 minutes (Pay attendant while waiting), then start up the engine.
11. Get everyone back on-board, untie, and go have fun!
How'd I do?
# 4 is the exact opposite of what you should do. Hatches, engine compartment should remain shut before and during fueling. Once fueling is done then sniff for gas, run blower, open hatches, etc. All electronics should also be off during fueling. If there is a switch for your bilge, turn it off.
From what I understand, engine hatches should be open. If anything, for one reason is to see if your filling your bilge instead of your tank.
Hatches closed prevents fuel vapors from entering engine compartment or cabin areas.
all hatches should be closed to prevent vapors from coming in and settling at the bottom.
bilge pumps can be left on auto, they are ignition protected anyway...
if you dont' have a vapor detector, install one NOW. no gas boat should be without one. It doens't replace the snif test but it will alert you right away if something happens while fueling (leak) or underway. a MUST HAVE.
As to not letting the attendant refuel, well it depends. Some fuel docks/trucks want the attendant to do it which isnt' a bad idea because he knows hsi equipment, delivery rate, etc... but when the attendant refuels my boat, I am still watching over his shoulder...
Wow, lots of misconceptions. Always, all hatches and ports closed to keep fuel vapors (always present during fueling) from settleing into those areas. Occasionally see someone who thinks they should be running the blower during fueling. NO.
So, my engine cover should be CLOSED, then I open it after fueling to check for fumes/spills?
Correct.
Vapors go down to lowest spot. You open your hatch your asking for them to go in.
If Fuel is going into your bilge you will smell it and it would of gone into the bilge before you got to the fuel dock!
Another thing that should be off is your cell phone, but noone ever does that one.
Bob, when your done, light a match to check for vapors.......kidding!
I couldn't pay the fuel jockey, he handed me the nozzle and walked off the dock. When he saw the
USCG talking with me, he left out of sight.
I wouldn't open the engine hatches cause there are hot engines under them. My engines are in the
cockpit. I have fuel flow meters with a totalizer. They are always within 1 or 2 gallons of the
pump meters. I usually see how much I burn and then slow down when it gets close. I seldom spill
gas in the water, much less enough to cover the area this one covered.
I never run the bilge pump blower until a couple minutes after stopping fueling. I have seen a 32 ft.
Trojan that ran it's bilge pump blower and sucked gas vapors into the hot engine room. BOOM.
I try to make sure most vapors are out of the area before starting the blower.
Timely reminder Bob
As to the side of the boat to put against the dock;
Other boats, wind directionvelocity, current, as well as shape, construction andor orientation of the fuel dock, are often more important considerations than which side ones fuel fill is on. I DO love perfect days though :-)
Stan
Originally posted by Estimator
Timely reminder Bob
Stan
Especially when one has fuel fills on both Port and Starboard. Then again I hardly ever fill both tanks from the same fuel dock.
While cruising the North Channel a couple of years ago I was most impressed with the Canadian fuel dock procedures. They all followed safety procedures to a "T", getting everyone off the boat (including me) and they do the pumping. On Lake Michigan I've had a full spectrum of experiences from complete self-service with no marina personnel on the gas dock at all, to very safety oriented marina personnel although the vast majority either require or allow me to pump the gas (which I am most comfortable with).
My gas dock insists the boater tie off the boat and pump the gas. This is for liability purposes, I am told. I'd rather do it myself anyway since I know the best way to prevent overfill and such.
Here are a few more
1/ No smoking
2/ Fire ext. available
3/ Drip trays on fuel vent(s)
4/ Use marinas rags if you can (this saves putting a gas soaked rag on your boat)
5/ Know approx. amount of fuel required before starting
6/ Make sure you are putting the right type of fuel in your boat before you start pumping
7/ Man the pump (easiest way to shut down fueling procedure if something goes wrong
8/ Absorbant material available
9/ Filler nozzle firmly in filler hole
I am sure there is more but this is all I could come up with off the top of my head
:I never run the bilge pump until a couple minutes after stopping fueling. I have seen a 32 ft.
Trojan that ran it's bilge pump and sucked gas vapors into the hot engine room. BOOM."
Bilge Pumps suck in Vapors?
I meant blower. Sorry bout that. Dang pain pills.
