proper kicker shaft length
pharmboy
I have a 2001 Crestliner Sportfish 1850 and will be putting a Mercury 9.9 kicker on it. The kicker will go on the side of the transom where it's 23.5-24 inches tall. Should I go with the 20" long shaft or the 25" x-long shaft. I fish in the Great Lakes so I come across some 5 foot roller waves. I'm worried that the 20" shaft will not get the prop far enough into the water, plus I only draft about 4-5 inches at that point in the transom. Almost all the dealers I ask say to get the 25" shaft. But when it comes down to actually purchasing one, I've had two dealers suggest one of the long shafts off the floor. Are they just trying to get me to buy one in stock, or would a long shaft really work in my setup? Thanks, Chuck
The anti-ventilation plate should not be lower than the hull. The plate should also not be above the water level at it's fastest speed. With 4-5" at the transom, just measure the distannce from the transom bracket to the plate and match it to the height where you plan to mount it.
