- May 12, 2009
- 31236
- 322
The water in my newly purchased used boat's domestic water tank is old. I need to drain the tank and refill it with fresh water. Opening sink valves will cause the pressure pump to want to re-pressurize the system. What's the best way to drain the tank without running the pressure pump dry? Or is it okay to run the pump dry? Will the pump need to be primed after refilling the tank? Will water gravity feed from the tank to the pump to prime it, or is there some other special way to prime it?
The boat's domestic water system does not include a tank tender or other monitoring system to tell me how much water is in the tank.
1982 Carver 3007. System includes a 12 gal. Raritan 120V AC water heater with a heat exchanger from the engines.
Advice would be appreciated.
