Pump out portapotti's
Monterey10
How well (in practice) do the portapotti's with the pump out work? I'm thinking of putting a Thetford 360 in my boat and am not sure if pumping is easier, or walking the tank to the bathroom is easier. You see this type of potti on the newer, small Trophy boats.
Thanks in advance.
I had one in my previous boat. If I remember correctly, you cant remove the tank unless you remove the hose clamps so it is much easier to just pump it out (thats what I did)
I had one for four years on my bowrider. If you have ready access to a pumpout, it very easy and convenient. Here every fuel dock has a pumpout that's usually free if you buy gas. Now if you trailer and fuel on-shore, then you have to make a special trip to pumpout. That might make carrying a bucket-o-sh!t to a toilet more convenient. Remember to pour carefully that stuff stains.
I have the SeaLand porta-potti hooked up to a pumpout system. Works fine; much better than carrying the holding tank to empty it. I have the 2-gal one; make sure to go with the largest capacity possible, especially if you have kids on board!
I have an installed portapotti with the exterior pumpout connections. Unfortunately, I do not have easy access to a pumpout facility because we trailer the boat to local lakes for day use and purchase our fuel on land. Hence I must use a Bissell Little Green carpet cleaning machine to suction out the day's waste. Not a nice task. I wish instead I could remove the entire unit and simply pour it into a toilet at home.
I have one on my Carver and it works great via deck pumpout fitting. Make sure you have the vent hooked up and that there are no kinks in any of the hoses. Keith has it right. Go with the largest capacity you can. Boatfix has a few available.
I have the sanipotti with the pumpout. The pumpout works fairly well...never seemes to totally empty out though...there's always a little left in the tank. After I pump out everythig I can, I hose in some clean water and continue to pump until the what's left is just water. Hope this helps.
My concern would be the availability of the pump out station. A portapotti does not hold very muych, you would have to pump it out almosty every day that it is used.
Pump outs by me cost $5-$10. I may sound cheap but for $20 a weekend, I would carry it to the toilet!!!!
The biggest problem I see with these things is they always underestimate just how long a family can use them before its time to dump/pump them out. So therefore if there is any way at all to go with the biggest possible unit, do so. I have a Thetford 875 MSD on my Glastron and it seems to work well. Then again I am a wierdo - since the "big" portapotti is mounted in the cabin under the stairs, I also carry a el cheapo Sears brand one in the cockpit for emergencies. And on the big boat, I replaced the glorified porta potti they had on there with a SeaLand Traveler unit (9.5 gal capacity - a GREAT portapotti alternative) but then also plumbed in a 35 gallon holding tank with macerator in between so I have nearly 45 gallons of $h!t on a 28 foot boat. Since we boat in upstate NY in relatively remote locations and may not pump out for 4 weeks or so, its very much worth it, especially since its the same charge for 5 gallons as it is for 45 gallons!!!
i had one on our old boat and it worked just fine. i was told to always pull the handle between the bowl and tank out before pumping out or the thing could implode. not sure if that's true or not, but that's the way i always did it and it always cleaned the thing out.
"...was told to always pull the handle between the bowl and tank out before pumping out or the thing could implode..."
I heard that's true if you install without a vent line. We had a vent line and never pulled the handle during pump-outs.
I pull [and instruct guests to pull] the little handle a tad open before lifting the lid. The little bugger has been known to spit, which can be very unpleasant.
