Pump will not shut off
summerwind
The boat is a 2009 Sea Ray 240 Sundancer. Under the deck drain in the Head compartment is a pump, not sure for what. All of sudden it does not shut off. Switched batteries to Off, still ran, finally disconnected battery cable to shut off this pump. Not sure what this pump is for? Or Why, all of a sudden would not shut off? There is not any access point to get at this pump? Any thoughts?
Quite possibly a shower sump like one of these, with hair or debris or just gomph on the hinges holding the float switch up: http://www.boatfix.com/catalog/564.pdf .
I'd think there would be a switch or breaker , but I suppose it's possible it was wired directly to the battery + (w/ inline fuse) similar to typical bilge pump float switches. If there is really no access, you may have to cut out the sole for an inspection hatch. Hopefullly someone with that model S/R has a better idea of what the story is in there.
That makes sense.
What did you mean by this? "you may have to cut out the sole for an inspection hatch"
The sole is the floor on a boat. ....If.... there is no access because they installed the sump before the cabin/head/cockpit liner ( as does happen ,to the delight of owners) then if you want that drain to pump out and not overflow, I'd imagine an unscrew or pry-out deck/plate inspection hatch might be needed. So that just refers to a maybe 8-10" dia cutout for the plate if you decide on that. If you get positioning info from SeaRay, that would allow cleaning of the sump pump & switch, but not the larger sump box. S/R may even have hints of how to access without cutting, especially on such a rcent model. Note , I am not familiar at all with that boat, so this is just general suggestion.
http://www.boatfix.com/catalog/650.pdf
Please understand that I'm not being arrogant but you need to learn about all the systems on your boat and the routine maintenance needs. Doing things like dcisconnecting the batteries is a dangerious solution as that will also disable your bilge pumps and you absolutely do not want to do that if the boat is in the water. The more you learn about the details of your boat the moreit will save you a lot of aggravation and a lot of money. Like others have said, I'm betting on the shower sump box/pump. First find the breaker for the shower and turn it off. Next, find the shower sump box and get access to it (I hope its not buried like Sandy described but that's not outside the realm of possibilities). There are likely 4 screws holding the lid on the box. Remove the screws, lift the lid off the box and look at the float switch (hopefully it has a separate float switch and not one that's internal to the pump itself). Clean the switch, pump inlets, the entire box then turn the breaker back on, run the shower and make certain that the pump goes on/off correctly. I'd then flush the entire system with some licquid bleach by pouring a cup down the drain in the shower. Let us know how you make out and if this correctys the problem.
All SeaRay shower sumps are wired to the hot bus, thus they will run and what MikeeH said is good advice. SeaRay shower sumps have a breaker on the breaker panel. That is your shut down point. Again, disconnecting the battery especially if the boat is in the water is bad business as now, your bilge pumps are also disabled. I recently had the same problem with my 270 and it is quicker and easier just to replace the entire assembly than to try and replace the switch in the sump box.
Not an uncommon problem your having. Mine is in a hard to reach spot also. I turned on the shower head and filled the sump and the float became un-stuck, lucky me.
In my case the float would occasionally stick in rough water.
We use our shower quite a bit being almost full time live aborads. My wife and I are on the boat 5 out of 7 days a week. We replaced the original sump box with a Rule box. They have a screen or hair trap and we can't go much longer than opening the box and cleaning everything including the trap. In my Mainship this required cutting an access square in the floor under the hall carpet. Now I can service the unit monthly and we have had no problems since the monthly cleanings.
It certainly sounds like the float switch on the shower sump is stuck in the on position.
There is a switch, circuit breaker, of fuse for this pump. There has to be unless some PO or hack bypassed it. If you can't find it, try the owner's manual, ask your dealer, or someone with a boat similar to yours.
finding the pump shouldn't be that difficult since it's running. Listen for it.
There will be a way to access the pump since it's something that requires routine service and winterizing. Again, check the owner's manual, ask your dealer, or someone with a boat similar to yours.
On my previous boat, the shower sump was under a step. Hint: It will be lower than the floor of the shower.
edit: If you shut the batteries off and the pump continued to run, it might be a bilge pump for a forward compartment, not a shower sump. A shower sump should be connected to the main battery switch.
Still, there is a way to access the pump. Look around or get some help. Contact the dealer if necessary.
That drain area is your shower sump. The float switch acivates the pump to pump out shower water. The float switch is probably stuck, and the pump should also be activated by switch at the helm labeled forward bilge.
Most of the smaller Sea Ray cruisers have the sump located under the step going to the cabin.
Lift up on the front on the step to access the pump.
That's where it was on my Glastron.
Some sump pumps are automatic and some have a switch. The boat I have now has a switch to turn it on and off located in the head. As well a switch on the master electric panel.
Sea Ray also puts a manual switch at the helm labeled "forward bilge pump". That manually activates the shower sump, which doubles as the condensate pump for the ac.
Thanks. This issue only started when we pulled her out of the water for the season. I wondered if running it up on the trailer triggered it. I do recall a pump under the step going down into the cabin and didn't think about that because I heard the sound coming out of the drain area, but then again inside the step area is sound proofed pretty good, I'll check the pump under the step.
do what mike said, first you need to identify what the pump does otherwise we can speculate until spring with no conclusion.
+1 what Bruce said.............
