I hope someone can give me a quick answer before Monday when Raritan is open, maybe Vic will check in. I'm installing a Purasan for two toilets, got everything in and working on the electricial. According to Vic I don't need to install the CVs(not sure that's the correct name). I've hooked up the power to the Purasan and a line from the forward toilet switch to the board on S2. This activates the Pursan and water valve, but the water valve only stays open as long as the button is pressed. I'm not using the switch supplied with the Purasan because if I understood correctly it's meant for one toilet connection not two.
The question...is the water valve suppose to activate long enough to fill the canister with water when the toilet button is pressed, or do you have to hold the toilet button for 10 secs to get enough water in the canister? Going back to the boat in the morning to finish up, hopefully someone has an answer so I don't have to wait until Monday. Maybe I'm wrong but I understood pressing either (forward or aft) toilet button would activate the Purisan and supply the correct amount of water to the canister without having to hold the button down for a certain time.
